B pillar harness bar for EG...
Hi guys- just soem quick questions -
WIll a DC/EK b illar harness bar fit a EG B pillar arrangement ? Or is there bars mad for EG hatch dimensions ?
Also , can u guys suggest some good online sites to purchase a bar to suit my EG hatch ?
Thanks a bunch
Thanks a bunch
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
I think you might mean the c-pillar, the rear seatbelts? In this case DC teg = EG/EJ. Same with b-pillar locations. I would just fab one up or take it to some metal worker and have him make you one. Be a lot cheaper and better than some online e-bay one with pivot points..
FROM WHAT IT SOUNDS LIKE,YOU WANT THE BAR THAT RUNS RIGHT BEHIND THE FRONT SEATS TO MOUNT RACING HARNESSES.SPARCO JUST STERTED TO PRODUCE A COUPLE MONTHS AGO.SEARCH EBAY.I HAVE SEEN THEM ON THERE ALREADY.IF YOU ARE TALKING ABOUT THE BRACE BAR THAT GOES BETWEEN THE REAR SEAT BELT POINTS,THAT IS A C-PILLAR BRACE.AGAIN HIT EBAY.GOOD LUCK IN YOUR SEARCHES
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SCIVIC94 »</TD></TR><TR><TD CLASS="quote">IF YOU ARE TALKING ABOUT THE BRACE BAR THAT GOES BETWEEN THE REAR SEAT BELT POINTS,THAT IS A C-PILLAR BRACE.AGAIN HIT EBAY.GOOD LUCK IN YOUR SEARCHES</TD></TR></TABLE>
No , i am talkign of the B pillar bar - that runs directly inbetween the passenger and drvier seat belt bolts. This bar is shown to increase rigidity much more than a C pllar.
Anyway , ill have a look on EBAY etc - anywhere else guys ? Does Nuespeed have one etc ?
Thanks.
Thanks.
hey ben.....you can get da B-pillar bar from whiteline automotive.......charles(autosalon magazine) had one in his EK before.
yes. alot of bars are interchangable, As long as the mounting locations and the bolt pattern is the same. reason is because i would say 75% of the bars that you buy have a lenght adjustment screw.
Just measure and order. I think the one I am using was for a porsche 911 but it is the same width so it fits.
Wish I could remember where I got it though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">yes. alot of bars are interchangable, As long as the mounting locations and the bolt pattern is the same. reason is because i would say 75% of the bars that you buy have a lenght adjustment screw.</TD></TR></TABLE>
so it wouldnt fit if it was nonadjustable?
Scotty Dosent Know
Oct 29, 2008 07:35 AM
