bad to drie with no secondaries?
Old May 6, 2005 | 04:35 PM
Liquidgsr's Avatar
Default bad to drie with no secondaries?
I just got my S200 with my P28. Is it bad to drive around like this. I have the stock gsr manifold. My friend told me its bad to drive around with the gsr manifold in there without the secondaries and i should get a skunk2 asap.
Old May 7, 2005 | 08:45 AM
Red Bull's Avatar
Default Re: bad to drie with no secondaries? (Liquidgsr)
its ok
Old May 7, 2005 | 04:15 PM
drdisco69's Avatar
Yeah, it's not going to suck them into the motor or anything. Why are everyones friends retarded?
Old May 7, 2005 | 04:29 PM
DOHCsideracing's Avatar
Default Re: bad to drive with no secondaries? (Liquidgsr)
The only thing I can think of that would be considered bad about not opening up the butterflies is that you would be loosing top end power. If you don't have access to a GS-R ECU, then I would suggest disconnecting the vaccum line that runs to the diaphram on the butterflies and plugging it with a scerw or something, or get a single stage intake mani...
You will loose some midrange power (3,000 - 5,750 rpm), but your top end will be "normal" (5,750+)
Old May 7, 2005 | 10:05 PM
Liquidgsr's Avatar
Default Re: bad to drive with no secondaries? (DOHCsideracing)
yeah i plugged in my stock ecu back in for now till i get the skunk2. Whats plus of having the skunk2 over the stock gsr and the hondata?
Old May 8, 2005 | 11:00 AM
If You Slip You Die's Avatar
why dont u just run hondata with your gsr ecu
Old May 8, 2005 | 12:19 PM
Liquidgsr's Avatar
Default Re: bad to drive with no secondaries? (05 EVO VIII GSR)
because my gsr ecu is not socketed
Old May 8, 2005 | 12:33 PM
drdisco69's Avatar
That can be solved easily enough...
Old May 8, 2005 | 03:17 PM
Liquidgsr's Avatar
Default Re: bad to drive with no secondaries? (drdisco69)
yeah i know don't want to mess with my stock ecu.
tomlinson619
Apr 14, 2006 04:26 PM
db8gsr_teg
Mar 22, 2006 10:50 AM
acura_b18c1
Oct 30, 2005 07:53 PM
ted
Jul 30, 2005 05:06 PM
dose
Jul 31, 2002 12:41 PM
