Volks TE-37 Offset question PLZ HELP
Old May 6, 2005 | 04:05 PM
n0odlez's Avatar
Default Volks TE-37 Offset question PLZ HELP
Hey guys, i have 3 Volks TE-37 Rims Bronze Sizes Is 15x7 Offset is .+35
I couldnt find another same size but i did happend to manage to find one Volks TE-37 Rim Bronze Sizes 15x7 Offset is .+42 difference of 8MM . ONCE I PUT THIS IN MY CAR can i tell the difference maybe you guys can help me out thanks.
O, by the way the size of the tires r 205/50/15's if that helps thanks
Old May 6, 2005 | 09:36 PM
.water's Avatar
Default Re: Volks TE-37 Offset question PLZ HELP (n0odlez)
sooo..what is ur question? lol
stock is +45 on tegs. so it will be better ones that close number to 45.
Old May 6, 2005 | 09:56 PM
XrcR6's Avatar
Since everything else is the same (rim width and all the tires are the same size), the corner you put that +42 wheel is going to be 7mm (last time I checked 42-35=7...) more inwards.
The smaller numerical value the offset number is, the farther outwards (from the hub/car) the wheel is placed. The higher numerical value the offset is, it brings it inwards.
How/what you use your car for and how attuned you are to a 7mm change in track width (biased on one corner), is hard for someone to guess across the Internet. But you could use 7mm of spacer on whatever corner you put that +42 wheel, so things are consistent /symmetrical again.
ColorblindBass
Dec 19, 2017 09:16 AM
mrbobolonian
May 10, 2008 07:32 AM
- BSeRiouS -
Honda S2000
71
Nov 28, 2006 11:07 AM
Nick H
May 10, 2002 04:20 PM
Double 06
Apr 12, 2002 04:22 PM
