Much needed install instructions for Golden Eagle VTEC Conversion System!!!
Old May 6, 2005 | 12:20 PM
X-Mazda 3 Racer's Avatar
Default Much needed install instructions for Golden Eagle VTEC Conversion System!!!
Old May 6, 2005 | 12:42 PM
Root79's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (jerseykid609)
There are much better system!
Old May 6, 2005 | 12:54 PM
stealthmode62's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (Root79)
Real nice write up.
Old May 6, 2005 | 01:11 PM
Rob Dizzle's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (stealthmode62)
added to my site incase the image doesnt work in the future and someone needs it.
Golden Eagle Install for Vtec conversion
Golden Eagle Install turbo oil feed
Modified by Rob Dizzle at 3:45 PM 5/6/2005
Old May 7, 2005 | 04:54 PM
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (Rob Dizzle)
Thanks for the good words guys. Up for the people that needed the instructions
Old May 7, 2005 | 05:05 PM
G
sh!t happens.
Great write up man..
Old May 9, 2005 | 03:07 PM
bboylito's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (G"UNIT)
wow i didnt realize it was that easy, guess who's doing an lsvtec lol
Old May 9, 2005 | 03:56 PM
Rod.'s Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (bboylito)
good info
Old May 9, 2005 | 04:21 PM
FredoSP's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (redturbocivic)
nice
Old May 9, 2005 | 04:35 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (FredoSP)
how about the wiring while you're at it
nickromeo's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (GoldenEagleMfg.com)
i would also like to point out that when i did this on my d16y7 for my turbo oil feed i gota a massive oil like when using a 3593 oil filter.
so if you're using 3593 filter use a 6811 (same thread) but its off some acuras (i beleive legendes) and the oil filter sits down all the way as oppsoed to a 3593 which the seal did not seat at all.
im not sure about oem honda blue fitlers.
Old May 9, 2005 | 04:36 PM
nickromeo's Avatar
*oil leak
Old May 24, 2005 | 05:36 AM
Doodoo's Avatar
So what if you install the dowels on the intake side? I have a stock headgasket and this is how they fit best in my setup without doing any modifications.
So the primary function of the dowels is to locate the head on the block and make sure the headgasket is aligned right. If this happens when the dowels are in the intake side of the block everything should be ok. Right?
Old May 24, 2005 | 06:46 AM
ITR981002's Avatar
Man, I thought something was missing from the kit I bought from you guys. It included DETAILED instructions on how to screw on a sandwich adapter, but nothing on what side the dowel pins should go on... or how to tap/plug the oil hole in the head. Seemed odd to me at the time.
Old May 24, 2005 | 06:50 AM
Si Shane's Avatar
lol, good timing!
Old May 24, 2005 | 06:59 AM
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (Si Shane)
Yeah, somehow the instructions have eluded the packaging. Sorry guys. If you know anyone else that may have this kit, please point them here for instructions
Thanks. My customers are the best
Vince
Golden Eagle Mfg.
Old May 24, 2005 | 07:08 AM
stackz's Avatar
at the jetties fishin'
Community Builder
do you make those oil filter adapters in house?? I'd be VERY interested in one for a ford 2.3turbo engine.
Old May 24, 2005 | 07:10 AM
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz &raquo;</TD></TR><TR><TD CLASS="quote">do you make those oil filter adapters in house?? I'd be VERY interested in one for a ford 2.3turbo engine.</TD></TR></TABLE>
Yes, all in house. What Ford motor are you talking about? Let me know
*EDIT* read your sig. Let me know what thread pitch and o-ring size your motor uses ( or just give me an oil filter number ) and I can see what we have.
Old May 25, 2005 | 03:08 AM
stackz's Avatar
Community Builder
3/4" - 16 TPI
Gasket 2.834 OD x 2.462 ID
sorry for the delay, but I got it measured last night and then promptly proceeded to forget to post the info haha
Old Jun 1, 2005 | 12:43 PM
RCautoworks's Avatar
Great post
Old Jun 1, 2005 | 01:03 PM
xenocron's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (90blackcrx)
Good stuff...got me thinking now
Old Jun 2, 2005 | 06:47 AM
B16Civic93's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (xenocron)
yeah, i always thought it was alot harder than this, i think i'm going to attempt the conversion now
Old Jun 9, 2005 | 11:03 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (B16Civic93)
got my kit today and went to put it on. my b16 head wont sit flush all the way, i cant get it on the dowels. and yes i have the small end in the block.
Old Jun 10, 2005 | 01:22 AM
GradyDC5's Avatar
I think the instructions eluded me too. I just studied everything, and it all came out okay. No instructions need ::thumpup::
Old Jun 11, 2005 | 06:59 AM
Lil Corb's Avatar
going to need this in a couple of months. Good info.
