Much needed install instructions for Golden Eagle VTEC Conversion System!!!
Old Jun 11, 2005 | 09:44 AM
  #26
Si Shane's Avatar
Default Re: (Lil Corb)
WANTBOOST
Make sure the dowels are in the correct location (around the outer most headstuds on the exhaust side of the block).
Dremel down part of the dowel, so its smaller. Or you can make your head hole larger I had ungodly amounts of trouble with the dowels. But use a dremel and a nice carbide/grinding bit and some vice grips (or hell a bench grinder might work real well, probably better) and go to town on the dowel. Make sure there is nothing in the hole to create extra friction between the dowel and the head.
Good luck.
Old Jun 11, 2005 | 10:23 AM
  #27
Rod.'s Avatar
Default Re: (Si Shane)
are you talking about having a gap with the dowels? I just went through this ...I had to use a rubber mallett to put the dowels in the block and hit the head with a rubber mallet too.
Old Jun 11, 2005 | 11:59 AM
  #28
wantboost's Avatar
Who is Mr Robot?
Default Re: (redturbocivic)
ill probably just bore out the dowel holes on the head, they do look a bit small. and getting the stock ones out was a bitch and a half.
theres a decent gap (.25") but ill get rid of that, lol
Old Jun 29, 2005 | 07:49 PM
  #29
jpangeles's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (GoldenEagleMfg.com)
how much is the sandwhich plate along cuz i aready have line and everything...and also i both the dowel pin from importpalace and the brand name is eagle...it didn't even fit in my gsr head...
Old Jun 29, 2005 | 09:20 PM
  #30
agrn93ls's Avatar
i built my LS/vtec myself using this kit. i love this kit it made the whole setup so much easier and most important as close to honda as it can get. the only thing i had to complain about was lack of instructions so i second guessed my self on the dowels and tapping the head. but it came out perfect. for GE. but the quality of the parts is amazing. thank you Golden Eagle.
one question i just ordered my turbo kit, a revhard kit. do you know if the -3AN line will thread directly into the oil sandwich? sorry i dont know exactly the thread type and size it will come with.
Old Jun 29, 2005 | 09:53 PM
  #31
1158's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (agrn93ls)
I assume you mean the smaller port. It is 1/8 NPT. You should be able to find a 1/8 NPT to 3 AN adapter though.
Old Jun 29, 2005 | 09:59 PM
  #32
integra_gsr98's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (1158)
I just finished putting a customer motor together using the LS/VTEC Install Kit, and other than using a rubber mallet to put the head down onto the dowels, it was an amazing kit.
I would recommend this kit to anyone.
Old Jun 29, 2005 | 10:17 PM
  #33
1158's Avatar
Default Re: Much needed install instructions for Golden Eagle VTEC Conversion System!!! (integra_gsr98)
I'm not doing an LS/VTEC, just putting on a turbo and I think the oil sandwich is worth it's weight in gold. Not only does the turbo get nice clean filtered oil, but I can hang the oil pressure sensor on it to boot! Best part is not having to deal with T-ing off the block. I just got mine today and it looks like a quality piece.
Old Jun 29, 2005 | 10:27 PM
  #34
wantboost's Avatar
Who is Mr Robot?
well, on my block (obd0 b18a) there isnt enough room for me to get the pressure sender on in the stock location... i do have a length of ss braided line to be used as a firewall kit, so i guess i'll just relocate the oil pressure sender to the firewall and tee off of the oil sandwich turbo feed for my oil pressure gauge (rather be monitoring oil pressure to the turbo i guess)
Old Jun 29, 2005 | 11:10 PM
  #35
Ef88Lsvtec's Avatar
Nice post
Old Jun 29, 2005 | 11:28 PM
  #36
SiKid86's Avatar
Default Re: (Ef88Lsvtec)
This needs to be saved some were easy possibly a sticky!
Old Jun 30, 2005 | 01:21 PM
  #37
X-Mazda 3 Racer's Avatar
Default Re: (SiKid86)
It will be able to be accessed on our website by next week. ALL of our instruction sheets will be available online then
http://www.goldeneaglemfg.com
Old Jul 10, 2005 | 02:40 AM
  #38
Ef88Lsvtec's Avatar
nice
Old Jul 10, 2005 | 05:17 AM
  #39
Rod.'s Avatar
the kit made it so easy to do at my house...golden eagle
X-Mazda 3 Racer
Apr 2, 2007 11:10 PM
X-Mazda 3 Racer
32
Feb 10, 2006 01:16 AM
modifyORdie
Jan 3, 2006 02:31 PM
peenut4head
Sep 29, 2004 07:31 PM
Project_SOHC_EX
Oct 5, 2003 11:34 AM
