Clutch decision: ACT, Exedy, Clutchmaster, RPS, SPEC
Old May 6, 2005 | 12:12 PM
dominate9's Avatar
Default Clutch decision: ACT, Exedy, Clutchmaster, RPS, SPEC
I am in the market for a new clutch. I am currently building a turbo H23/VTEC. The car will be a daily driver and might see the track once a month...if lucky. I want something that I can drive in rush hour traffic as well as hold power when I crank up the boost. So I don't want an "on and off switch". I want to run about 11-12 psi on stage 1 and 15 on stage 2 with my Turbo XS DSBS. I'm estimating at least 350HP at 15 psi. The following clutches are the ones I am debating on. I currently have an ACT HA3-HDSS (heavy duty plate and street disc).
1. Exedy Stage II Thick Disc Cerametallic. It has a sprung 3-puck disc. 75% increase over stock.
2. Clutchmasters Stage IV (FX-400), 6-puck sprung disc. 170% holding capacity over stock(whatever that means) or Stage III. street disc. 110% increase
3. ACT HC3-HDR4 (Heavy Duty Plate and 6-puck UNsprung disc). Holds 356ft-lbs
4. RPS Max with street disc, 48% clampling increase,supposedly hold 440ft-lbs
5 SPEC Clutch Kit w/ ceramic 6-puck sprung disc, supposedly holds 360ft-lbs
Does anyone have experience with two or more of these clutches? I've never heard of the last two, so I'm the most skeptical about them. I could use some recommendations. Can anyone lead me in the right direction?
Modified by dominate9 at 12:17 PM 5/8/2005
Old May 8, 2005 | 08:17 AM
dominate9's Avatar
bump
Old May 8, 2005 | 05:36 PM
h22 civic's Avatar
Default Re: (dominate9)
i had a c/m stage 4 with a h22turbo at 12 psi made low 300s whp and was daily driven worked great
Old May 8, 2005 | 05:40 PM
dominate9's Avatar
Default Re: (h22 civic)
nice...anyone else?
Old May 9, 2005 | 06:33 AM
tgreaves's Avatar
I had a Exedy cerametallic thin clutch in my old crx setup.. Now im using a Clutchmaster FX500 in my new one..
Old May 9, 2005 | 07:18 AM
dominate9's Avatar
Default Re: (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">I had a Exedy cerametallic thin clutch in my old crx setup.. Now im using a Clutchmaster FX500 in my new one..</TD></TR></TABLE>
So what is your experience with them? Any recommendations?
Old May 9, 2005 | 07:25 AM
tgreaves's Avatar
The Exedy clutch was great and never slipped.. It had smooth engaugement and easy pedel pressure..
Old May 9, 2005 | 09:40 AM
Wilky's Avatar
Default Re: Clutch decision: ACT, Exedy, Clutchmaster, RPS, SPEC (dominate9)
Action clutch - you can get it at Wiredspeed.com - I got one at Rocket's reccomendation. Highly reccommended.
Old May 9, 2005 | 12:44 PM
dominate9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">The Exedy clutch was great and never slipped.. It had smooth engaugement and easy pedel pressure..</TD></TR></TABLE>
And the one you have now?
Old May 9, 2005 | 12:46 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dominate9 &raquo;</TD></TR><TR><TD CLASS="quote">
And the one you have now?</TD></TR></TABLE>
Ill let you know tommorow since that will be the first time that it has been driven..
Old May 11, 2005 | 05:46 AM
b18psi's Avatar
I have a 300whp turbo teg and am also looking for a new clutch. I have the exedy thin cerametallic and my only complaint is that it only lasted a year with 4 track days with slicks. I now wish I would have gotten the thick disc. I have been doing some research and found that exedy has a very weak pressure plate with only 1560 clamping pounds. Same pressure plate as their stage 1. So I don't think I am going to go with Exedy again for this reason. For a comparison ACT pp are 2100, 2500 and 2900 clamping lbs which are stronger than most on the market. I like the clutchmaster stage 4 but the price is high. Clutchnet.com looks pretty good with their 6 puck sprung but Rocket's post here on Honda-tech said their disc will eat through your flywheel. At the moment I like eclutchmaster.com stage 2, thier pp is 1900 which is still weaker than any ACT but a lot stronger than the Exedy I have now. And their clutch disc is a six puck sprung with a new material called MIBA which is suppost to grip like cerametallic but engage smoother and wear less on you flywheel. Hope some of this info helps.
Old May 11, 2005 | 05:50 AM
tgreaves's Avatar
Default Re: (b18psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18psi &raquo;</TD></TR><TR><TD CLASS="quote">I have a 300whp turbo teg and am also looking for a new clutch. I have the exedy thin cerametallic and my only complaint is that it only lasted a year with 4 track days with slicks. I now wish I would have gotten the thick disc. I have been doing some research and found that exedy has a very weak pressure plate with only 1560 clamping pounds. Same pressure plate as their stage 1. So I don't think I am going to go with Exedy again for this reason. For a comparison ACT pp are 2100, 2500 and 2900 clamping lbs which are stronger than most on the market. I like the clutchmaster stage 4 but the price is high. Clutchnet.com looks pretty good with their 6 puck sprung but Rocket's post here on Honda-tech said their disc will eat through your flywheel. At the moment I like eclutchmaster.com stage 2, thier pp is 1900 which is still weaker than any ACT but a lot stronger than the Exedy I have now. And their clutch disc is a six puck sprung with a new material called MIBA which is suppost to grip like cerametallic but engage smoother and wear less on you flywheel. Hope some of this info helps.</TD></TR></TABLE>
Did you break the Exedy clutch in properly? I was running the same clutch on my drag crx for over a year and never a problem, the clutch also had lots of life left on it when I changed setups..
Old May 11, 2005 | 05:55 AM
b18psi's Avatar
Yes, I broke it in for 500 miles. My car is heavier than yours so it might cause more wear.
Old May 11, 2005 | 06:43 AM
dominate9's Avatar
No one heard of RPS or SPEC? What about that Action Clutch that Rocket recommends?
Old May 11, 2005 | 06:50 AM
b18psi's Avatar
I like RPS but have heard bad things about Spec. I don't like Action because Rockets thread is biased therefore I don't trust him. My #1 clutch is the Exedy Hyper single but it is $1000.
Old May 11, 2005 | 11:02 AM
Bee18Hatch's Avatar
I got an Excedy in my Hatch, and I love it.......Never slips, no problems
Old May 11, 2005 | 11:06 AM
clutchmasters's Avatar
[/i]</TD></TR></TABLE>
170% holding capacity over stock means that the stage 4 will hold stock hp + (1.7*stock hp), for example if the stock hp rating is 150, then the FX400 wil hold: 150+(1.7*150) = 150+(255) = 405HP.
Hope this clears things up a little for you, let me know if you have any other questions..
Thanks
Old May 11, 2005 | 02:17 PM
dominate9's Avatar
Default Re: Clutch decision: ACT, Exedy, Clutchmaster, RPS, SPEC (clutchmasters)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clutchmasters &raquo;</TD></TR><TR><TD CLASS="quote">170% holding capacity over stock means that the stage 4 will hold stock hp + (1.7*stock hp), for example if the stock hp rating is 150, then the FX400 wil hold: 150+(1.7*150) = 150+(255) = 405HP.
Thanks</TD></TR></TABLE>
Cool. So where can I get good deals on the Stage IV. I am leaning more towards that side.
Old May 11, 2005 | 03:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dominate9 &raquo;</TD></TR><TR><TD CLASS="quote">Cool. So where can I get good deals on the Stage IV. I am leaning more towards that side.</TD></TR></TABLE>
You can give these guys a call, your in Florida right?
RACE ENGINEERING, INC.
http://www.raceeng.com
2602 PARK STREET
LAKE WORTH, FL 33460
Phone561) 533-5500
Old May 19, 2005 | 09:27 PM
dominate9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clutchmasters &raquo;</TD></TR><TR><TD CLASS="quote">You can give these guys a call, your in Florida right?
2602 PARK STREET
Phone561) 533-5500</TD></TR></TABLE>
$420...damn bump
Old May 19, 2005 | 09:28 PM
dominate9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">i had a c/m stage 4 with a h22turbo at 12 psi made low 300s whp and was daily driven worked great </TD></TR></TABLE>
Had? So what do you have now? How long did the last clutch last?
Old May 19, 2005 | 11:43 PM
pcguy760's Avatar
$420...damn bump</TD></TR></TABLE>
$420 DAMN MAN. But hey you know the old saying "You get what you paid for..."
I think it would pay off in the long run.
Old May 20, 2005 | 03:35 AM
dominate9's Avatar
Default Re: Clutch decision: ACT, Exedy, Clutchmaster, RPS, SPEC (pcguy760)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pcguy760 &raquo;</TD></TR><TR><TD CLASS="quote">$420 DAMN MAN. But hey you know the old saying "You get what you paid for..."
I think it would pay off in the long run. </TD></TR></TABLE>
Yeah, but I'm looking for a deal... and RACEENG doesn't seem to have it. Aren't there any Clutchmaster dealers out there!?!?
full Circling
Feb 5, 2008 01:44 PM
mademan2723
May 19, 2004 07:57 PM
supergreenNA1
Mar 11, 2002 09:04 PM
88CRXHybrid
Feb 8, 2002 12:51 PM
PressurizedSi
Sep 17, 2001 05:21 AM
