HELP! tranny making sounds
Old May 6, 2005 | 06:27 AM
onetrueshyguy's Avatar
Default HELP! tranny making sounds
Hi, i have a problem with the car
whenever the car is in gear the car would make little noises like scratchy ratty noisy, i am pretty sure it's coming out from the tranny
my question is, do i need a new tranny or is there something cheap i can replace it with so it doesn't make that sound anymore? it's very disturbing to hear the screeching sounds
Old May 6, 2005 | 06:40 AM
Brownjd's Avatar
Default Re: HELP! tranny making sounds (onetrueshyguy)
sounds like bad tranny bearings. get them replaced soon
Old May 6, 2005 | 06:53 AM
Default Re: HELP! tranny making sounds (Brownjd)
thanks for the quick reply
how much does that cost around?
Old May 6, 2005 | 07:01 AM
Brownjd's Avatar
need a little more info. does it make noise when your in nuetral and have your foot off the clutch pedal? or does it make noise just when your moving?
Old May 6, 2005 | 07:05 AM
DaX's Avatar
DaX
Loved
Community Favorite
The cost per bearing can range from $15 to $75, depending on what transmission you have and which bearing is getting ready to take a dirt nap.
Replacing the bearing yourself is an option, but I warn that you'll need certain tools to do this properly, and if it's a D-series tranny we're talking about, it gets a little more difficult.
Fill us in with some info on what tranny it is and the nature of the noise.
Old May 6, 2005 | 08:51 AM
Yes the tranny only makes noise when it is in gear, when it is crusing on neutral the sound disappears
and yes it is a stock SI tranny, so I'm assuming it is rather difficult to do without the right tools?
Old May 6, 2005 | 09:48 AM
Brownjd's Avatar
Default Re: (onetrueshyguy)
it's hard to know unless you have someone look at it. could be tranny, clutch, release bearing, pressure plate, or any combination of these
JaviITR
Jul 31, 2009 10:40 AM
importnoodles
Apr 16, 2007 01:34 PM
MasterSaif
Mar 15, 2004 08:20 AM
HXvtec
10
Oct 16, 2003 04:39 PM
Bbasso
Sep 14, 2003 11:17 PM
