gsr cluster qucick ??
you need the electric vss the b series is what you need b/c the motor is an xsi...is that a ys1. Replace the vss...and run teh wire to the ECu. some dude took the time and wrote it all out.. from the B16a2 wiring the Si cluster. It's basically the same b/c they use electric speed sensor....
if your car is still obd0 you can use a cable driven vss, which came off a 90-91 integra ls. I'm not sure if the 92-93 were cable driven, but i know for sure that the 90-91 cable vss will work. For example I am using a 90-91 integra cable driven vss in my 98 itr transmission. Hope this helps.
mmmmm 2 threads about same thing......................interesting............ ..
go here for answer https://honda-tech.com/zero...38817
RACEPAK
Nov 9, 2023 07:24 AM
dannyb18c
May 11, 2012 02:04 PM
kin_8
Oct 9, 2005 08:40 AM
wickedEFguy
Dec 16, 2002 03:51 PM
