shift linkage questions
Old Feb 3, 2002 | 09:50 AM
Random.Hero's Avatar
Default shift linkage questions
How do you take the damn thing out? Also, if I were to get an aftermarket one for my R, how much would I be looking at and what brand? Until I know how to get this peice off, my car remains on jacks, so responses needed! Thanks!
Old Feb 3, 2002 | 10:14 AM
JPP's Avatar
JPP
Default Re: shift linkage questions (YellowITR01)
Can you be more specific on wich linkage you are talking about. The is two arms under the car. One is connected to the pivoting point of the shifter. The other one is connected at the end of the shifter.
From the service manual I have in front of me, the only place to disconnect that is not visible is at the connection to the tranny, where there is a rubber boot. You have to push the rubber boot toward the front of the car, there is a clip under the boot that you need to remove and that holds a spring pin in place, when you remove the spring pin, the linkage should slide off.
Good luck
Joe-G
Feb 22, 2008 11:03 PM
b18c4door
26
Nov 23, 2007 04:47 AM
arrojj
Feb 15, 2006 02:10 PM
Grimm
Nov 4, 2003 05:04 AM
made in JAPAN
Jan 31, 2003 08:22 PM
