B18 engine problems .. over heating
Old May 5, 2005 | 06:19 PM
777sC's Avatar
Default B18 engine problems .. over heating
95 GSr ...
my car is over heating and i don't know y ... i cant find a single problem with it
when i driving normal its ok temp but as soon as i accelerate the temp jumps up and goes almost to the H ... if i slow down or shift it out of gear then the temp drops ... then sometimes it just jumps around very fast
Ive gotten a check engine light but it turns off as soon as the car is shut off and it does it very rarely ... when the light is on there is no Vtec
HELP ME i want to go to the track tomm
these are the things i have done to it so i know its not the cause of the problem
-New head gasket (done right)
-milled head just to make sure its straight
-new thermostat
fans turn on perfectly
Old May 5, 2005 | 06:45 PM
sickerhatch's Avatar
Default Re: B18 engine problems .. over heating (777sC)
radiator clogged ?? bad temp gage??
Just some ideas.
Old May 5, 2005 | 08:19 PM
k00lt1nt's Avatar
Default Re: B18 engine problems .. over heating (sickerhatch)
could be ur sensor...most likely..i had the same problem...i jess rewired my fan also
Old May 5, 2005 | 08:41 PM
Circuit Star-29's Avatar
Default Re: B18 engine problems .. over heating (k00lt1nt)
its your Temp switch....
Dre told me so...
Old May 5, 2005 | 08:50 PM
777sC's Avatar
Default Re: B18 engine problems .. over heating (C-speed Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Racing &raquo;</TD></TR><TR><TD CLASS="quote">its your Temp switch....
Dre told me so... </TD></TR></TABLE>
yep ... found out the problem
longzorz
Apr 7, 2010 02:34 PM
91EF_Si
Feb 11, 2010 08:24 AM
whookid007
Oct 11, 2006 07:05 PM
ProjectLSVTEG
Jun 14, 2005 03:00 PM
FATBOYeg6
17
Mar 1, 2005 05:51 AM
