using obd1 throttle body
Old May 5, 2005 | 04:13 PM
type Gendy's Avatar
Default using obd1 throttle body
Anybody in here using an obd1 throttle body that has the map sensor on the tb instead of the firewall like it is on crx's and civics?
I bought an ls TB and had it maxbored, and it had a hole on top of it that looked like it should have a hose attached. Apparently its where a map sensor belongs.
Just wondering, all i have to do is get an ls map sensor and plug it in and reroute the wires/ hose?
Old May 5, 2005 | 07:04 PM
type Gendy's Avatar
Default Re: using obd1 throttle body (type Gendy)
nobody?
Old May 5, 2005 | 07:05 PM
HatchBox's Avatar
Skoobie no more...
nope. not me
Old May 5, 2005 | 07:13 PM
type Gendy's Avatar
Default Re: using obd1 throttle body (HatchBox)
Throw that bbk er rpm on , whatever u have, its big
Old May 5, 2005 | 07:14 PM
dr_latino999's Avatar
I was wondering the same thing but I also am looking for a throttle body that doesn't have the FITV on the bottom either.
Old May 5, 2005 | 07:15 PM
type Gendy's Avatar
Default Re: using obd1 throttle body (dr_latino999)
Thats why i ended up with this clunker, i NEED teh fitv. Car runs like **** without it
Old May 5, 2005 | 07:17 PM
HatchBox's Avatar
Skoobie no more...
sold it
talk to waylon about the map sensor, i know he had a issue with that when he did his GSR swap.
I think he just used the map sensor on the firewall. not sure about the vaccum line.
Old May 5, 2005 | 07:18 PM
What motor are you using that it runs like crap without?
Old May 5, 2005 | 07:19 PM
type Gendy's Avatar
b16a - cold starts u have to manually choke it to keep the car running, idle goes way low sometimes at intersections... nothing but problems
I'll have to ask him..good point. HE musta switched to an obd1 map, but then again he probably had one...
Old May 5, 2005 | 07:20 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy &raquo;</TD></TR><TR><TD CLASS="quote">b16a
I'll have to ask him..good point. HE musta switched to an obd1 map, but then again he probably had one...</TD></TR></TABLE>
he had 2 one on the firewall one on the tb
Old May 5, 2005 | 07:21 PM
type Gendy's Avatar
LMAO, musta kept the one on the firewall for "show"
lol
Old May 5, 2005 | 07:25 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy &raquo;</TD></TR><TR><TD CLASS="quote">LMAO, musta kept the one on the firewall for "show"
lol</TD></TR></TABLE>
he didnt use the one on the tb ...so that one was for show.
Old May 5, 2005 | 08:20 PM
DocSean's Avatar
I have the same question too, bump for some on-topic answers.
Old May 5, 2005 | 08:29 PM
type Gendy's Avatar
Default Re: (spankjelly)
has anybody tried to see if the crx map will work for obd1 tb map?
Old May 5, 2005 | 09:05 PM
HOND PWR's Avatar
Default Re: (type Gendy)
I put a obd1 tb on my car. Only problem I ran into was the wire was too short...had to add about 3 inches, plugs are the same.
Old May 6, 2005 | 05:05 AM
Default Re: (HOND PWR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOND PWR &raquo;</TD></TR><TR><TD CLASS="quote">I put a obd1 tb on my car. Only problem I ran into was the wire was too short...had to add about 3 inches, plugs are the same.</TD></TR></TABLE> We know that , or hence we would ask how to do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankjelly &raquo;</TD></TR><TR><TD CLASS="quote">I have the same question too, bump for some on-topic answers.</TD></TR></TABLE>
type Gendy is looking for one with attached MAP and FITV
I am looking for one with just the MAP.
Old May 6, 2005 | 10:16 AM
type Gendy's Avatar
Default Re: (dr_latino999)
I'll go try to fit my crx map to the ls tb, in hopes that it fits, and all i have to do is extend the wires
Old May 6, 2005 | 10:27 AM
Aren't our wall mounted MAP sensors different?
Old May 6, 2005 | 11:14 AM
type Gendy's Avatar
I guess they must be, because top mounts screw down on tb with hole on bottom...ares screw up into bracket with hole on bottom...guess theres no way they could fit.
WTB: obd1 map sensor
Old May 6, 2005 | 11:22 AM
HOND PWR's Avatar
I think I have a extra map sensor (I'll let you know Sat). I have a 89 HF, like I said above I had to extend the wires. Other than that it functioned right. Went with a obd1 t-body off a 95 GSR.
Old May 6, 2005 | 11:28 AM
type Gendy's Avatar
obd1 map?
Old May 6, 2005 | 08:52 PM
HOND PWR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy &raquo;</TD></TR><TR><TD CLASS="quote">obd1 map? </TD></TR></TABLE>
yea, I think I saved a extra dx throttle body for parts.
Old May 6, 2005 | 09:30 PM
DocSean's Avatar
So what you are saying is that the plug from the wall mounted MAP goes fine into the throttle body mounted MAP...you just have to extend the wires?
Old May 6, 2005 | 09:34 PM
type Gendy's Avatar
I'm assuming hte plug is the same between the two maps...can somebody verify?
Old May 7, 2005 | 07:15 PM
type Gendy's Avatar
can somebody post up a pic of an OBD1 map sensor?
i'm wondering if i can use something off a spare motor
