rust on tranny. safe to put on?
Old May 5, 2005 | 10:25 AM
junkyardRx's Avatar
Default rust on tranny. safe to put on?
i've had my replacement transmission sitting out for awhile and it's been through rain and all that and built up some surface rust on where the axles insert to. will this be ok to put on? thanks.
Old May 5, 2005 | 10:27 AM
DaX's Avatar
DaX
Loved
Community Favorite
...please tell me you had all the openings plugged. If not, you've probably got water in your tranny...a sure fire way to sieze your bearings.
Surface rust on the case is fine. Rust on the steel 'spring' inside the axle seals is not ok. Water in your transmission killing your bearings is not ok.
Old May 5, 2005 | 10:33 AM
junkyardRx's Avatar
Default Re: (DaX)
crap. yeah the plugs were open and water got into it and everything so i guess there goes my transmission swap. anyway just wanted to make sure before throwing it away. thanks for your help, i guess i'm in the market again for a new tranny.
Old May 5, 2005 | 10:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
Open the drain plug and see what the fluid looks like. Try spinning the tranny by hand and see if you can feel any tough spots, or hear anything that sounds nasty.
What tranny is it? Don't toss it...they can ALWAYS be fixed. Hell, if you're going to toss it, I'll pay shipping to toss it my way. My garrage is already a Honda tranny orphanage.
Old May 5, 2005 | 10:43 AM
Loaded Butane's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote"> My garrage is already a Honda tranny orphanage.</TD></TR></TABLE>
Sadly I jknow how that is. Except mine is more like a graveyard
Old May 5, 2005 | 08:34 PM
junkyardRx's Avatar
Default Re: (DaX)
haha, i'm not sure if it's a dx or si tranny but i'll test it out and see what happens. how do i go about fixing this? anyway i'll get back to you to see how it feels. thanks again.
Old May 5, 2005 | 11:40 PM
DaX's Avatar
DaX
Loved
Community Favorite
D-series trannys can be a pain when it comes to tearing down the shafts, but opening the case is a cinch. You'll be able to spot all the problematic bearings once inside.
sd619jef9
Apr 20, 2011 09:32 PM
julyef8
Nov 11, 2010 01:13 AM
Kaspk
Feb 10, 2007 02:02 PM
ECKOTYPER
Apr 9, 2004 08:26 PM
