4 x 100 Wheels, Options?
Old May 5, 2005 | 08:36 AM
GatorMark's Avatar
Default 4 x 100 Wheels, Options?
I'm looking for low-cost 4 x 100 wheels for a 91 Civic LX my daughter will be driving. I need 15" to fit the planned Civic brake upgrade. Did Honda, or Acura make any 15" wheels fitting the 4 x100 pattern? I figure factory cast-offs taking up room in someone's garage would be the cheapest way to acquire the wheels.
If not, would it be costly to change the hub to a different pattern? Don't the older Accords and Vigors use 4 x 117 pattern?
I'm taking the steering knuckles to get the bearings replaced this afternnon so if I need to change the hub, now would be a good time.
I did check the FAQs and couldn't find relevant info (or missed it).
Thanks,
Mark
91 Civic
00 GP GTP
Old May 5, 2005 | 08:44 AM
EP3_05's Avatar
Default Re: 4 x 100 Wheels, Options? (GatorMark)
Any civic/integra(except type-r) wheel is 4x100. It is just a matter of finding an oem 15" wheel such as the ones off an integra gsr. Good luck
Old May 5, 2005 | 08:46 AM
CRX Toad's Avatar
Yeah almost any Honda 4 lug wheel will fit except Accord, Prelude, you can get a rim from a 96-00 Civic, 01- Civic, 94+ Intergra they will all fit. I also think that HX rims will clear brakes but I have no first hand knowledge of this.
You'll be hard pressed to find factory take offs to pry out of anyones grip...we EF guys are part mongers. Once we latch onto a set of 15" the price better be right...however you can find nice wheels out there people do get rid of them...I stick with the factory 4x100 hub but to each their own
jrunager
Oct 4, 2012 06:22 AM
sjung86
Honda Civic (2006 - 2015)
Dec 11, 2008 02:18 PM
tharpey
Feb 24, 2008 02:15 AM
seannabend
Oct 12, 2004 07:51 AM
flat-blk-HB
Nov 25, 2002 05:53 PM
