Alignment question - is this right?
Old May 5, 2005 | 08:22 AM
Toldge's Avatar
Default Alignment question - is this right?
Went in for an alignment for 55 bux. They came back and said that my rear wheels both had a negative 1 camber. They said it needed to be +5. I was charged 20 bux per side for shims, so in total, my alignment was 95 bux. Sound correct?
Old May 5, 2005 | 09:19 AM
deserthonda's Avatar
what year and model??? did you get a print out of the before and after alignment results?? if so post it here ,, if not see if you can get it and post it here
Old May 5, 2005 | 09:31 AM
Toldge's Avatar
Default Re: (deserthonda)
96 accord ex, I only saw the before print out, and they didn't give me a copy
it only took the guy 20 mins to shim both back wheels, i feel like that should have been included with the the alignment
Old May 5, 2005 | 02:51 PM
i bet all they did is remove the bolts for the upper control arms and put a washer back there to make camber more positive
Old May 6, 2005 | 07:08 AM
SpeedFreak77's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">i bet all they did is remove the bolts for the upper control arms and put a washer back there to make camber more positive</TD></TR></TABLE>
That is what a shim does, don't mean to sound rude or anything. The cost of the alignment sounds right, anytime they have to go in and install anything most companies usually charge for it because they are doing more than just adjusting your camber and toe.
JDMCRX
Suspension & Brakes
10
Apr 11, 2013 04:57 AM
alexm
Suspension & Brakes
16
Apr 27, 2009 11:52 PM
lambertincorp
Suspension & Brakes
Oct 7, 2007 10:41 AM
96civich22
Suspension & Brakes
35
Apr 1, 2005 02:11 PM
RineRacing
May 8, 2002 05:03 AM
