Where can i get this repaired
hi guys...is there a good welding shop in Glendale, CA 91204 to fix this tranny case?
and know how much it will cost?
thanks in advance guys,
Kamal
Kamal
Yellowbook -> Welding
Probably looking at a half an hour or so to build up the material at $70/hour. Little bit more time if you need it drilled and tapped.
check on a price for a new side of the tranny casing and then get a price for the welding job....... you might be able to buy the brand new case for around the same price
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
LOL, maybe if he needed to pieces of the case welded, let say for example this is a GSR trans... This part is $375.67 retail and Delray Acura out of FL would discount it to $300.46, but all that comes with is the breather cap and the oil gutter plate. I personally wouldn't resuse the shim but the rest of the stuff should be good. Here is a link to where I got this info from..
http://www.acuraoemparts.com/d...ch=no Happy Tuning!!! Get it welded BTW..
haha well i didnt look up the price of the case first so i didnt know how much it was......... so yea ignore what i said cus it would probly be better to just get it fixed
yea i heard of the JB welds....i hear they are cool....but isnt that expensive?
nobody done this before in cali? cause i dont i want to ship to a shop to do this job!
if you honestly search around hard enough you can find a used case.. iknow there are plenty of shop around that has these cases laying around that are in good condition... and take it to a tranny shop and let them swap it out... You are lucky becuase that is the easy side to replace.. all you have to do is pop the back off that broke and pop the new one in without even touching any of the gear set....
Used case.. $100 max
1 1/2 hour labor max to swap case... $120
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTR-FAB »</TD></TR><TR><TD CLASS="quote">if you honestly search around hard enough you can find a used case.. iknow there are plenty of shop around that has these cases laying around that are in good condition... and take it to a tranny shop and let them swap it out... You are lucky becuase that is the easy side to replace.. all you have to do is pop the back off that broke and pop the new one in without even touching any of the gear set....
This would certainly work and is 100% correct. Now if it was the clutch housing then I would suggest just getting a new trans and using that one for parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTypeR »</TD></TR><TR><TD CLASS="quote">yea i heard of the JB welds....i hear they are cool....but isnt that expensive?
nobody done this before in cali? cause i dont i want to ship to a shop to do this job!</TD></TR></TABLE>
LMFAO!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baseballinmyass »</TD></TR><TR><TD CLASS="quote">jb weld cost like 5 bucks it's a type of glue/epoxy resin stuff</TD></TR></TABLE> Yeah a glue/epoxy, I wouldn't suggest it for anything that A. has to be threaded and B. has to hold any amount of weight. Now the other side mount bolt MAY be able to completely support the weight of the trans but I wouldn't chance it. Look at your pic again and let us know how you would feel if BOTH were fucked like that...
HAPPY TUNING!! or fixing in this case..
LMFAO!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTypeR »</TD></TR><TR><TD CLASS="quote">Can u PM with an offer DTR-FAB? cause i it says in your signiture you do Tran fab, so am guessing u can help!</TD></TR></TABLE>
i couldn't weld this becuase chances are it probably wont line up the threads correctly and would be more of a hassle to fix... swaping back casing is a sure and garuantee fix...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTypeR »</TD></TR><TR><TD CLASS="quote">bump
is there a place in Glendale CA where i can weld fill this problem and at the same time do a tranny rebuild?</TD></TR></TABLE>
if the case is bad and you need a rebiuld i think your better off buying a good used tranny to replace this one
nothing wrong with the tranny as i was told by the seller, but i just want to fit new bearings, seals and syncros to make it all good and new when installing the new LSD!
Modified by IntegraTypeR at 9:32 AM 6/3/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTypeR »</TD></TR><TR><TD CLASS="quote">nothing wrong with the tranny as i was told by the seller, but i just want to fit new bearings, seals and syncros to make it all good and new when installing the new LSD!
Modified by IntegraTypeR at 9:32 AM 6/3/2005</TD></TR></TABLE>
do you have any clue how much syncros cost ? if you dont mind spending 1000 in parts then ok rebiuld it ... but syncros go for about 300 each
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baseballinmyass »</TD></TR><TR><TD CLASS="quote">just fill the hole with loc-tite 809 and be done with it.</TD></TR></TABLE>
never heard of that! can u tell more about it like it a temp job?cheap?...etc
i've been told on several occasions that the tranny case can't be welded or JB Welded.something to effect of it being very porous aluminum,and that is would crack back out eventually...don't know how true that is,maybe some of the experts here can agree or disagree.
with two different tranny cases that i've broken myself,as well as with a couple for friends,i've bought whichever half of the case is broken used,and never had any problems.i've paid from $25 to $50 for either half for D and B series cases.you will need to reshim the mainshaft and diff,and it's not a bad time to freshen up everything while you're in there.
currently i'm fixing the LS tranny that i did have in my beater.i got the clutch housing for $50,replaced all the sealed bearings(OEM from Sunnyside Acura-good prices),and got the Gearspeed carbon synchro rings.i've got about $350 in parts so far.
it could very well be cheaper to buy another used tranny.it just depends on if you can do the work yourself(labor will add up quick),and how much needs to be replaced.it also depends on if you want to have another used tranny that you're not certain of it's past.this tranny i'm currently rebuilding will be going in my coupe,which will by fall have over 500WHP-i want it to be bulletproof.if it were going back in my 140HP beater,i'd probably bypass all the hassle and just buy another used tranny.
BTW-i noticed you said that the seller told you the tranny was in good shape.i wouldn't count on anything.this LS tranny of mine that just exploded was bought from sombody on here.they claimed it had low mileage and was in perfect shape.it had a horrible bad bearing noise from the day i installed it,and finally the diff exploded
Chris
Chris
well the seller told me that the diff of this tranny i have something bad and told me that if i really intended to fit an lsd it that tranny would be perfect for me which i understand the seller is being honest and he did recommend new bearings and syncros or is it syncro bearings?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTypeR »</TD></TR><TR><TD CLASS="quote">well the seller told me that the diff of this tranny i have something bad and told me that if i really intended to fit an lsd it that tranny would be perfect for me which i understand the seller is being honest and he did recommend new bearings and syncros or is it syncro bearings?
did he mean the diff had broken?if so,that can cause some serious damage.fragments of metal from the diff can ruin gears,bearings and bust through the case.
Chris
</TD></TR></TABLE>did he mean the diff had broken?if so,that can cause some serious damage.fragments of metal from the diff can ruin gears,bearings and bust through the case.
Chris
what tranny is it I have many cases b,d,f,h. I am getting ready to clean out my storage units and have several broken trannys bad bearings, cracked cases etc but also have many good parts. If you just want the case you are depending on which one $25-75 plus shipping and I am in florida.
Hope I helped
alex
Hope I helped
alex
well the the tranny is a 99 b16 hydro and need the last case as u can see! so let me know your price shipped! if u have anything else that could help me in my rebuild that would be nice!
Modified by IntegraTypeR at 3:06 AM 6/6/2005
