rc 1000cc injector stuck open? new
Old May 4, 2005 | 09:33 PM
BoOsTiN Dc2's Avatar
Default rc 1000cc injector stuck open? new
I've installed 1000cc injector and all 4 injectors are stuck open, there brand new so i'm not sure what the problem is. I've use a voltmeter to test it and there is power going thru the clip and the ohms look good also. When i unplug the injector clips and turn the key the fuel sprays out like crazy. Its not electrical because i checked already and i have a resistor box. Its running on a hondata basmap for 1000cc injector. Anyone know what it could be? I've tried everything i could think of, my next step is maybe send it back to RC to have them check it. BTW its so much fuel that it leaks thru the back of the JG manifold where the vacuum connects to.
Old May 5, 2005 | 05:11 AM
Default Re: rc 1000cc injector stuck open? new (tRaCeBuStAbUsTeR)
bump
Old May 5, 2005 | 05:36 AM
DXK Eg's Avatar
Are you sure they are new, if so send them back...There mess up bad.
Old May 5, 2005 | 05:37 AM
Default Re: rc 1000cc injector stuck open? new (dynasty-x-motorsport)
yeah there new i got them directly from rc
Old May 5, 2005 | 05:54 AM
Turbowa's Avatar
Deff. send them back. There is now way they shouldbe doing that straight out of the box.
Old May 5, 2005 | 07:39 AM
bigblockvtec's Avatar
Default Re: rc 1000cc injector stuck open? new (Turbowa)
i know someone who is experiencing this thing also. please update us whatever happens. he is running hondata also and 1000cc.
Old May 5, 2005 | 07:43 AM
SOHC_MShue's Avatar
damn i bet thats a lot of fuel spraying out if they are stuck wide open
Old May 5, 2005 | 09:05 AM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">When i unplug the injector clips and turn the key the fuel sprays out like crazy.</TD></TR></TABLE>
WTF are you talking about? Did RC send you their magical injectors that work without being plugged in?
Old May 5, 2005 | 09:13 AM
b18bturbo's Avatar
the RC higher end injectors are notroious for sticking i had the same damn problem on a set we had to send them back.
bought hte precision bosch 1600cc and was done with my fueling needs.
Old May 5, 2005 | 11:28 AM
SOHC_MShue's Avatar
Default Re: rc 1000cc injector stuck open? new (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">WTF are you talking about? Did RC send you their magical injectors that work without being plugged in?</TD></TR></TABLE>
I think he means that they are stuck open so they spray even when not being plugged in.
Old May 5, 2005 | 12:18 PM
Muckman's Avatar
Moderator in Chief
Default Re: rc 1000cc injector stuck open? new (SOHC_MShue)
haha thats awesome
Old May 5, 2005 | 02:20 PM
Rtype16's Avatar
Try this unplug your ECU (hondata) and turn the key back on and see what you get. You may need to turn your fuel pump on though.
Old May 5, 2005 | 03:30 PM
Default Re: rc 1000cc injector stuck open? new (Rtype16)
if i unplug the hondata the fuel pump won't get power to it. How can i go about doing that Rtype16?
Old May 5, 2005 | 04:04 PM
Rtype16's Avatar
Unplug the computer and give the fuel pump power and ground atthe connector.
Old May 5, 2005 | 06:41 PM
yeah im pretty sure its the injectors because i swapped out 440 saturated and it was kool. Then i tried the 1000cc injector again and it was still the same. Only thing i change out was the hondata and the resistor box because the saturated cant use those. Unless its something with the resistor box or hondata? i doubt it though. Im trying to see if i can send it back to RC but there customer service kinda sucks so what u guys think? If i bring it somewhere else would they be able to fix it or should i just get new injectors?
Old May 5, 2005 | 09:48 PM
turtle-eg's Avatar
OT, but aren't you using RC 1200cc injectors? Why the switch to 1000cc?
Old May 6, 2005 | 03:28 PM
Default Re: rc 1000cc injector stuck open? new (turtle-eg)
i got 2 sets. a set of 1000cc and 1200cc. I decided to use the 1000cc instead because its plenty for me already
ehwreckuno
K Series
Mar 20, 2016 05:18 PM
99siky
Dec 23, 2012 01:55 PM
turboteg2nv
Dec 2, 2004 03:53 PM
trbob16a
Apr 17, 2003 12:41 PM
