what does the iat sensor do?
Old May 4, 2005 | 08:02 PM
civic_tuned's Avatar
Default what does the iat sensor do?
today i was checking my sensors because i had a fluncuating idle and my engine does a sort of stall and sputters. i replaced the tps sensor and put it to specs. I cleaned the iacv. I checked the map and the iat. The map is working fine except the iat. i checked it with voltmeter at 20dc's and it gave a 1.89-2.00. Is this bad? I want to make sure i checked it right. I tapped the + needle to the red wire and the -needle to the green wire. I checked my haynes book and it said that the voltage should be between 3.5-5.5 is this correct or am i wrong. Here it goes with my stupid ? what does the iat do?
Old May 4, 2005 | 08:12 PM
Frozen E's Avatar
H-T White Ops
Default Re: what does the iat sensor do? (civic_type_r)
senses intake air temp?
Old May 4, 2005 | 08:17 PM
Default Re: what does the iat sensor do? (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">senses intake air temp? </TD></TR></TABLE>
i guess
Old May 4, 2005 | 08:48 PM
c'mon guys!
Old May 5, 2005 | 05:55 AM
EE_Chris's Avatar
The IAT tells the ECU how hot the coolant is...duh.
C'mon now - IAT - intake air temperature - not that hard. Because Honda's use a Speed-Denisty type of fuel injection system, the volume of air entering the engine is not directly measured, as it is in a MAF based car. The temp of the air must be known to calculate this volume.
Temp/Voltage:
60*/3.35v
70*/3.08v
80*/2.81v
You can also use the ECT sensor as a reference value to compare to the IAT when the engine has been allowed to sit overnight. They share the same output characteristics.
pgk1025
May 1, 2020 07:52 AM
EFstyle
11
Jul 28, 2008 06:45 PM
the.hamburglar
Sep 2, 2006 02:36 PM
ah789454
May 27, 2005 11:16 AM
Layziebtnh055
Apr 14, 2004 07:58 AM
