slight vibration at 70 -80mph whats wrong?
Old May 4, 2005 | 07:23 PM
ViruS05's Avatar
Default slight vibration at 70 -80mph whats wrong?
Stock 95 civic suspension and when i go on some of the not so smooth highways I have a vibation in the ride, but not so much if at all on other highways, maybe something is worn at 150,000? Anyone know what the problem is?
Old May 4, 2005 | 07:30 PM
needVtec's Avatar
Default Re: slight vibration at 70 -80mph whats wrong? (ViruS05)
balance your tires
Old May 4, 2005 | 07:31 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: slight vibration at 70 -80mph whats wrong? (needVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by needVtec &raquo;</TD></TR><TR><TD CLASS="quote">balance your tires</TD></TR></TABLE>
not when braking right?
ViruS05's Avatar
brand new and balanced tires as well as new front cv joints
Old May 4, 2005 | 07:32 PM
ViruS05's Avatar
Default Re: slight vibration at 70 -80mph whats wrong? (CoupeVtec2k)
just when riding but the vibration is more so at about 70 then gets less as I hit 90
Old May 4, 2005 | 07:33 PM
jlacoy82's Avatar
71.192.16.183
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViruS05 &raquo;</TD></TR><TR><TD CLASS="quote">brand new and balanced tires as well as new front cv joints
Alignment, tie rods, axles, tires, cv joints, etc?
Old May 4, 2005 | 07:52 PM
ViruS05's Avatar
Default Re: slight vibration at 70 -80mph whats wrong? (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">
Alignment, tie rods, axles, tires, cv joints, etc?</TD></TR></TABLE>
Alignment done right before the new axles/cv joints were put in then the new tires, now vibration. maybe I need another alignment...
EJ8VTEC's Avatar
Mr. Indecisive
axles</TD></TR></TABLE>
Old May 4, 2005 | 07:56 PM
ViruS05's Avatar
Im thinkin complete suspension overhaul in the next few months
Old May 4, 2005 | 08:50 PM
PURPLETERROR aka BIGMATT's Avatar
tierods, lower baljoints and an alignment
Old May 4, 2005 | 08:52 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: slight vibration at 70 -80mph whats wrong? (PURPLETERROR)
do u have the stock rims on???
Old May 4, 2005 | 08:54 PM
litterbox's Avatar
I am a (Trial User) Army
I've got the same problem and I've got:
New tie rods 1000miles
ball joints have 29000miles on them
new struts/springs 1000miles
New balanced Ziex's 1000miles
Alignment 1000miles
I have a possible bad wheel bearing, but axles are fine, would that cause it?
Old May 4, 2005 | 08:59 PM
xEnderx's Avatar
Default Re: slight vibration at 70 -80mph whats wrong? (litterbox)
Tire balance woudl be my guess. If it is in at a specific speed regardless of engine RPM or gear selection then its tires hands down. If it is ONLY under acceleration then its your axles......under braking, then its uneven rotors or possibley a bent slider.
Old May 4, 2005 | 09:00 PM
litterbox's Avatar
Default Re: slight vibration at 70 -80mph whats wrong? (xEnderx)
Sorry, forgot to mention, new and balanced Ziex's 1000miles.
Old May 4, 2005 | 11:41 PM
hatch34's Avatar
wheel bearing
Old May 6, 2005 | 07:10 PM
needVtec's Avatar
Default Re: slight vibration at 70 -80mph whats wrong? (hatch34)
if its not balancing then machine your rotors if it swhen you brake
Old May 6, 2005 | 07:51 PM
EeeJayEight's Avatar
wheel balancers only account for up to 80 mph or so i hear... also if ur tires are passenger tires which arent rated for speed... that could be an issue..
Old May 6, 2005 | 08:32 PM
SD1222's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch34 &raquo;</TD></TR><TR><TD CLASS="quote">wheel bearing</TD></TR></TABLE>
jdimi34
Apr 15, 2008 04:49 PM
Young L
Mid-Atlantic (Sales)
Sep 27, 2006 08:11 AM
RUBZERK
Jan 15, 2005 12:51 AM
stsRacer22
42
Jan 11, 2005 09:10 PM
1Tym
Jun 20, 2003 06:46 PM
