Lack of sway bar question
Would a lack of a front sway bar on a 93 hatch cause extreme loosness and play iin the steering. Like i turn the steering wheel in the car, im about to buy and it seems like there little turn in the wheels untill i get passed 10 degrees in each direction.
Your car shouldn't do that. Get under the dash board & inspect the "U" joint in the steering column. I have read in another thread that somebody found theirs was going bad, and they had major play in the steering. The U joint (#13) is underneath a cover (#12) between the pedals. There should be two clips (#14/15) around the plastic cover, and then two plastic nuts (#40) holding the cover to the floor. My CRX also had a push type clip (#38) that I just yanked out by pulling the cover up off the floor. There is also a second U joint built into the steering column (#10). If that one is bad, you will have to replace the colunm...
There's also an adjustment on the steering rack guide (big plug #4) that can possibly cause the looseness. Rack guide (#5) presses the rack against the pinion. Get your hands on a Helm book for the proper tensioning procedure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. »</TD></TR><TR><TD CLASS="quote">Honda's suspensions are very weak.. only downside to honda..
ummmmmmmmmmm NOOOOOOOOO your wrong. l
what honda are you driving, those crx / civic must not be yours!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
what honda are you driving, those crx / civic must not be yours!</TD></TR></TABLE>
LOL... Well coming from an EX E30 M3 owner, the Honda's arent as strong as the Bimmers are...
LOL... Well coming from an EX E30 M3 owner, the Honda's arent as strong as the Bimmers are...</TD></TR></TABLE>
just in case you haven't noticed this honda tech, not bmw tech, so who cares
Bumnah
Jan 7, 2003 06:51 AM
