What Exactally Causes Heat Warpage?
Yeah I Know The Obvios Is Heat But What Exactally Happens? I'm Running Into The Problem Of Warping Head Flanges When Building Exhaust Manifolds. So I'm Trying To Better Understand What Is Exactally Going On So I Can Prevent This From Happening. Thanks
Kyle
Kyle
Put the flange onto a head or jig and hold it down. Its just the fact that the welding heats the metal upto a point where some shrinks/expands and then warps on cooling.
Use jig/head...
Use jig/head...
Basically, heat allows the atoms to move more freely. The rate at which it cools determines where they stop (what kind of pattern), and different patterns take up different volumes. So you have warpage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richeybrooks »</TD></TR><TR><TD CLASS="quote">THE HEAT!</TD></TR></TABLE>
Thanks Captain Obvious
I would bolt it to a Jig or head like mentioned above.
Corey
Corey
are they mild steel or ss?
when you heat metal up in expands, when it cools in contracts, and not necessarily back into the same position. i would say you are getting your metal too hot. when welding you want to heat up the metal as little as possible.
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95c1v1cs1 »</TD></TR><TR><TD CLASS="quote">
Corey</TD></TR></TABLE> I personally would use a jig, a whole lot cheaper to replace if you warp that as opposed to the head. Just IMO..
JDMlyfestyle
10
Nov 14, 2004 05:42 AM
Lo-Buck EF
10
Jun 7, 2004 10:56 AM
