No fuel line pressure
Old May 4, 2005 | 06:36 AM
greenblurr93's Avatar
Default No fuel line pressure
Yep as the title says.. my b18c1 swap isnt getting gas (no line pressure).. checked the fuse...main relay... but nothing... anyone have ideas???? Thanks in advance.
Old May 4, 2005 | 10:54 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: No fuel line pressure (greenblurr93)
stupid idea but is the fuel pump working?
Old May 4, 2005 | 01:52 PM
Default Re: No fuel line pressure (HOOKUPS)
it was working when i started the swap, and i havent touched the fuel system except to disconnect lines (obviously)
Old May 4, 2005 | 03:15 PM
DYNO-PRO
sounds like the pump is not working
Old May 4, 2005 | 08:08 PM
Jmunk's Avatar
Is the ECU good ? Everything grounded ?
Old May 5, 2005 | 10:39 AM
Default Re: (Jmunk)
Got the fuel pump to work... now i am getting pressure, but it still wont start.
Old May 6, 2005 | 01:01 PM
sadangryboi's Avatar
if starter turns..check harness plugs on distributor...if distributor is good...take it off and check rotor....if rotor is good check wires and plugs....if thats good check all ur fuses and ecu fuse...if thats good and it wont start i cant help u...hope this helps haha
Old May 6, 2005 | 02:46 PM
Default Re: (sadangryboi)
haha, ya it would be a huge help if i didnt either check or replace all of what you just mentioned, but thanks anyways.
Elijahdaniel
Feb 27, 2016 07:07 PM
TexasluvsHondas
Nov 21, 2006 07:37 PM
ronqqq
Jun 2, 2005 07:11 PM
Gumbey75
Feb 26, 2005 10:32 PM
hwnstyle21
Sep 8, 2002 02:14 AM
