ls turbo...keep b16 tranny or get gsr tranny
Old May 3, 2005 | 11:33 PM
boostedeghatch's Avatar
Default ls turbo...keep b16 tranny or get gsr tranny
opinions?
Old May 4, 2005 | 06:13 AM
quicksol95's Avatar
Default Re: ls turbo...keep b16 tranny or get gsr tranny (Mr.DC2TurBo)
gsr
Old May 4, 2005 | 06:15 AM
Rod.'s Avatar
u cant go wrong with either one
Old May 4, 2005 | 06:37 AM
blackeg's Avatar
Default Re: ls turbo...keep b16 tranny or get gsr tranny (redturbocivic)
gsr tranny is golden on an ls. i shift at redline 7k and drop back into gear at between 5000 and 5200 rpms .
the b16 trans will get annoying at your low top speed, especially since your car will get up to 100+ mph much faster now
Old May 4, 2005 | 06:53 AM
HipHapa-Eg's Avatar
From: Where friends and family is all that matters, CA
Default Re: ls turbo...keep b16 tranny or get gsr tranny (boostedeghatch)
GSR .. longer gear ratios + turbo =
Old May 4, 2005 | 08:51 AM
Blue98Ex's Avatar
Default Re: ls turbo...keep b16 tranny or get gsr tranny (HAPA-EG)
GSR Great on the LS in my opinion
Old May 4, 2005 | 10:44 AM
Default Re: ls turbo...keep b16 tranny or get gsr tranny (Blue98Ex)
so many different opnions on what tranny to use.
from what i've read, longer gears aren't always better.
i'm thinking with the b16 tranny, i may have traction issues, not sure.
Old May 4, 2005 | 10:49 AM
92civicb18b1's Avatar
I would say get the GSR. Like you said you might have some traction issues with the b16 tranny. Plus you'll still have a semi-short/semi-long with the GSR. IMO it's the best all around tranny.
Old May 4, 2005 | 10:50 AM
_entropy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAPA-EG &raquo;</TD></TR><TR><TD CLASS="quote">GSR .. longer gear ratios + turbo = </TD></TR></TABLE>
No, you clown.
Longer gears + turbp =
Appropriate gears + turbo =
It's not so much the traction issue with a B16 trans as much as it's you're running out of gear because you can only turn around 7000 RPM's with the LS.
Old May 4, 2005 | 10:59 AM
sean's Avatar
Default Re: ls turbo...keep b16 tranny or get gsr tranny (Napoleon Dynamite)
im using a itr trans on my boosted ls. it feels great. it go with the b16 if you already have it.
Old May 4, 2005 | 11:03 AM
Rod.'s Avatar
Default Re: ls turbo...keep b16 tranny or get gsr tranny (sean)
i have driven a ls turbo w/ gsr tranny in a crx...it felt great
Old May 4, 2005 | 11:17 AM
jdjustme's Avatar
keep the gsr tranny beccause is good.
Old May 4, 2005 | 11:46 AM
99lspwr's Avatar
Default Re: ls turbo...keep b16 tranny or get gsr tranny (jdjustme)
Man, this topic has been beaten to holy hell!!!!!Do a search you will find lots of info...Also I used a ls trans with my hatch (ls motor) and would top out 120 at the top of fourth gear on a 24" tall slick!!! Gsr would be even worse, and a b16 would be horrible!!!
kcjohnnyboy
Oct 10, 2006 04:55 PM
SacTownsGreatest39
Apr 20, 2005 01:00 PM
92-EG6
30
Mar 14, 2004 06:18 AM
Kp_VtekNiks
Dec 24, 2002 03:26 PM
