Bad/horrible gas mileage ..plz help
I have terrible gas mileage on my mini-me, running a p28..this set-up is draining my gastank like its draining my wallet. I have a 1-wire o2 and I know the p28 is 4-wire is this the reason why? Also I got desprate and found a po5,p75, and I tried to hook them up but the it started to smoke from the ecu/ecu plugs what the hell caused this..but it seems it didnt do any damage..anyone can explain this to me and try to help my gas mileage improve with any suggestions, I'm all ears...
Oh its running rich, I can smell it, at idle, red lights, and when I park in the garage. I do have some CEL's but I havent check them.I did the mini-me and swap to the p28 right away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e2000 »</TD></TR><TR><TD CLASS="quote">I do have some CEL's but I havent check them.I did the mini-me and swap to the p28 right away.</TD></TR></TABLE>
Maybe you should...
Maybe you should...
I'm getting codes 10 and 41..
10 is (IAT) Intake Air Temp.
41 is Primary oxygen sensor heater
Modified by e2000 at 12:08 PM 5/4/2005
Modified by e2000 at 12:14 PM 5/4/2005
..I had no codes before the mini-me swap, so I think code 41 is because its a 1wire o2 compared to the 4wire o2 the p28 is looking for..where is the IAT anyone have a picture?
I have a jdm d15b head/manifold so some sensors like the Purge Valve Control are not on this manifold..there is a white sensor though so its must be it, have to screws..is the plug also white in thats hooks up 2 it?
nathanjohnson2009
Nov 25, 2010 07:09 PM
bmw626
31
Jun 5, 2005 04:58 AM
