Crx Front Brakes.
Old May 3, 2005 | 08:00 PM
CRX-SIR's Avatar
Default Crx Front Brakes.
Hello, before anybody flames me i searched for this and i couldent find the answer to my question. So my question is, i have Calipers off a 93 del sol i was wondering if they would bolt up to my stock crx brakes( i have a si) i also have the master cylinder.
I am just wondering if they will bolt up to the existing parts on my rex.
Please dont flame me about spelling or anything.
thanks
__________________________________________________ ____________
Proud Owner of a 89 CRX
Old May 3, 2005 | 08:15 PM
bagpipe goatee's Avatar
i doubt they'll fit, but all my knowlege regarding del sol's is hearsay.
but, what could be on there, it'd be ones similar to the ones on your 9.5 inch brakes, where there would be no plus to switching them
it could be similar to the ones the EX's, SIR's, and integra's use (which is what i assume) which, if you could just bolt those calipers on, people wouldn't be buying the other knuckles.
or, as a third possibility, it could be different from either of these, take off a wheel and hold it up, tell us what you find
Old May 3, 2005 | 08:16 PM
shawn_crx's Avatar
Default Re: Crx Front Brakes. (CRX-SIR)
If they are the same diameter then yes.
Pretty sure they do.
MC should fit too... Just make sure it's the same size.
Don't want to degrade and lose brake power.
Old May 3, 2005 | 08:22 PM
EL Vap133's Avatar
Put them next to each other, they might fit. I used a 90 dx civic caliper on my 97 Civic and it fit fine.
Old May 4, 2005 | 10:17 AM
CRX-SIR's Avatar
Thanks for all the posts guys, im gonna try and see if the calipers bolt up today. I will tell you if they work or not.
Old May 4, 2005 | 07:44 PM
CRX-SIR's Avatar
I have one more question..... When swaping from the old 9.5inch rotors to 10.2 integra rotors, can a 93 civic EX front knuckle work? Ive herd that the integra knuckle throws off alignment and stuff.
THanks
Old May 4, 2005 | 09:16 PM
CRX-SIR's Avatar
anybody?
Old May 5, 2005 | 10:08 AM
CRX-SIR's Avatar
Bump.
Old May 6, 2005 | 10:04 AM
CRX-SIR's Avatar
Bump
Old May 6, 2005 | 10:08 AM
EL Vap133's Avatar
Default Re: (CRX-SIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-SIR &raquo;</TD></TR><TR><TD CLASS="quote">I have one more question..... When swaping from the old 9.5inch rotors to 10.2 integra rotors, can a 93 civic EX front knuckle work? Ive herd that the integra knuckle throws off alignment and stuff.
THanks</TD></TR></TABLE>
It's about the same as the Teg knuckle. Might as well go with 90-93 Teg front brakes, knuckles and all.
SiRay6
Jul 24, 2020 02:03 PM
Corksil
Nov 7, 2011 12:31 AM
stock4now
Mar 21, 2006 08:23 PM
beardugo
Feb 10, 2006 07:14 PM
