Detachable Wheel VS. Airbag Wheel?
Well im thinking of getting a detachable wheel so that i have one extra feature against theft but what is stopping me is that i dont want to loose my airbag on my oem wheel. So which ever side you guys are on please state your reason on what you have on your car and convince me to go to your side.
Thanks
Spence
Thanks
Spence
thas a hard choice i would go with the airbag though because u only got one life to live...... my coupe i kept the airbag it was tuff but i think i made the right choice, besides there are other ways to prevent theft.
if you get a splash hub..or hkb, they give you a resistor of some sort, so at leastyou passenger wont die...*assuming that the resistor will trick the srs system into thinking it has both airbags that work...so when you get hit, the passenger side will still pop....*
i'd stick with oem airbag wheel.
detachable wheel requires cage, seat, 4 or 5 point seat harness to be safe.
Other then that, i'd stick to what EPA tested as safe on my car (oem belts, oem seats, oem airbag wheel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG »</TD></TR><TR><TD CLASS="quote">i'd stick with oem airbag wheel.
Other then that, i'd stick to what EPA tested as safe on my car (oem belts, oem seats, oem airbag wheel)</TD></TR></TABLE>
ZING!!!
ZING!!!
thanks guy i guess i would much rather i dont have a car cause someone stole it then to be messed up from a accident thanks for everyones opinions
Modified by Spence at 7:59 PM 5/4/2005
a1320addict
May 4, 2007 02:56 AM
Mugenlude
30
Jul 5, 2005 02:25 PM
