Anyone have a problem shifting?
Old May 3, 2005 | 01:50 PM
New Dimensions's Avatar
Default Anyone have a problem shifting?
Only happens to me when i'm going into third quickly, it seems to grind a bit when i'm putting it into place, other than that all the other gears are fine. A friend said maybe the syncros where bad? Anyone else have an idea?
Old May 3, 2005 | 01:53 PM
Bcuz's Avatar
Default Re: Anyone have a problem shifting? (New Dimensions)
What year civic is it? could be warranty. How many miles and I'll check the ISIS network for Honda Techs.
Old May 3, 2005 | 02:09 PM
Default Re: Anyone have a problem shifting? (Bcuz)
96ex with 80 and some change.
Old May 3, 2005 | 02:12 PM
StreetEG's Avatar
when i shift quickly between 2nd and 3rd and 3rd and 4th on my b16 tranny i feel a little roughness.... not too good
Old May 3, 2005 | 02:13 PM
Bcuz's Avatar
Sorry cuz I looked nd no recalls. My bad dude I hate giving bad news. Good news is it's honestly not that hard to fix.
Old May 3, 2005 | 03:10 PM
its cool, thanks though. like i said though its not to bad, but its noticeable if i shift real fast/hard. and its only third. kinda odd.
Old May 3, 2005 | 03:38 PM
Toolman's Avatar
If you want to test if the syncro went bad, double clutch before shifting into 3rd.. if there is no grind then its the syncro..
Old May 3, 2005 | 04:40 PM
JDMTurboCivic11's Avatar
Default Re: (Toolman)
i have the same problem, grinds almost every time under hard conditions and sometimes in daily driving
Old May 3, 2005 | 04:52 PM
igo4bmx's Avatar
i have no problems with 3rd gear, but switching from 1st to 2nd gear at a high rpm, it takes a second before i can shift into gear...
Old May 3, 2005 | 04:56 PM
Bcuz's Avatar
Default Re: (igo4bmx)
Alot of these grinds are from shifting too fast with the stock trans. I recently had to print something for a customer that shifted way too fast, and I had to replace 3rd synchro. If I find it, I'll post it just can't remember what service news it was under.
Old May 3, 2005 | 04:59 PM
slotec's Avatar
Default Re: (Bcuz)
3rd gear grind for me too in a 92-5 civic only in higher rpms( 4k and up)
Old May 3, 2005 | 05:27 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (slotec)
thats what started in mine, if ur **** grinds, double clutch or drive easy or it will go down hill from there, first hand experiance for me
Old May 3, 2005 | 05:30 PM
slotec's Avatar
Default Re: (CoupeVtec2k)
solution= buy a used jdm tranny for a few hundred bucks with good synchros
Old May 3, 2005 | 05:38 PM
slo97coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">i have no problems with 3rd gear, but switching from 1st to 2nd gear at a high rpm, it takes a second before i can shift into gear...</TD></TR></TABLE>
my 97 cx does that exact same thing what is it ....blah im swapin my engine soon soo so shouldnt matter too much longer
Old May 3, 2005 | 06:20 PM
jeez, seems like alot of people have the same problem.
Old May 3, 2005 | 06:54 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (New Dimensions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slotec &raquo;</TD></TR><TR><TD CLASS="quote">solution= buy a used jdm tranny for a few hundred bucks with good synchros</TD></TR></TABLE>
i got a JDM GSR trans for my b16 i think it should be stronger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek97-DAP &raquo;</TD></TR><TR><TD CLASS="quote">
my 97 cx does that exact same thing what is it ....blah im swapin my engine soon soo so shouldnt matter too much longer</TD></TR></TABLE>
my swap is on the way 7 days.... i cant wait
Old May 3, 2005 | 06:57 PM
blurrrcivic94's Avatar
synchromesh!
Old May 3, 2005 | 06:58 PM
slotec's Avatar
Default Re: (blurrrcivic94)
im gunna try that seriously, does advance or like autozone sell synchromesh
Old May 3, 2005 | 07:21 PM
MiMiK's Avatar
i have the same problem. i can shift to 3rd and 4th as quickly as i want but 2nd is always a pain. it's like it has to stop in neutral then go into 2nd...
Old May 3, 2005 | 07:42 PM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slotec &raquo;</TD></TR><TR><TD CLASS="quote">im gunna try that seriously, does advance or like autozone sell synchromesh</TD></TR></TABLE>\
yup i believe so
Old May 4, 2005 | 06:03 AM
slo97coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoupeVtec2k &raquo;</TD></TR><TR><TD CLASS="quote">
my swap is on the way 7 days.... i cant wait </TD></TR></TABLE>
what engine r u getting.... and how much
Old May 4, 2005 | 09:59 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (ek97-DAP)
what engine r u getting.... and how much</TD></TR></TABLE>
b16 sir2 complete swap w/ gsr lsd trans for $2880 shipped from hmotorsonline, a bunch of ppl r tellin me i shouldnt have gotten the gsr trans cause im goin to loose like .5sec off my time
Old May 4, 2005 | 10:16 AM
turbo_b16_ex's Avatar
same problem here. to make u frightened, my tranny took a **** on me yesterday. its whining, grinding and 1st gear hardly works. maybe thats next for you. muhuhahahaha
Old May 4, 2005 | 10:22 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (turbo_b16_ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_b16_ex &raquo;</TD></TR><TR><TD CLASS="quote">same problem here. to make u frightened, my tranny took a **** on me yesterday. its whining, grinding and 1st gear hardly works. maybe thats next for you. muhuhahahaha</TD></TR></TABLE>
i know what u mean
Old May 4, 2005 | 10:29 AM
NonovUrbizniz's Avatar
Loved
I had noises and some grinding a LONG time ago... I switched to Redline MTL and it COMPLETELY went away... now almost 100k miles later the input shaft bearing is occaisionaly making a noise like it's going to go...
But for 30 bucks or so in tranny fluid I got an extra 100 thousand miles out of my trans... I had mechanics telling me that it was time to start looking for a new trans.
Just a side note... I've since replaced the Redline with penzoil's synchromesh Not friction modified and it seems to shift just as smooth...
I highly recomend looking into this before shopping for a tranny.
Also it could be a VERY long time even on whatever fluid is in there now before the gear is actually in-accessable/unusable.
What kind of fluid is in there now?
thundernoodle
Transmission & Drivetrain
Aug 1, 2010 06:20 PM
anavrin351
Honda Civic (2006 - 2015)
15
Apr 26, 2007 01:21 PM
OnePointFive
Aug 30, 2004 04:34 PM
onyx00
Jul 20, 2002 02:11 AM
TypeR01-424
Nov 19, 2001 10:42 PM
