OBD2 B18C(R) EF RUNNING CAN IT RUN OBD1
Old May 3, 2005 | 01:47 PM
gato5254's Avatar
Default OBD2 B18C(R) EF RUNNING CAN IT RUN OBD1
My question is that looking to trade my bike for a EF, and i have a 96 hb with a 96 ITR swap done. But i like the the older body style. I'm running my motor OBD1 right now with a p28 ecu. I think the EF's are obd0 and the motor OBD2 but i want it to run obd 1. can some one tell me if i have to change any parts or get a harness made or what. thanks
Old May 3, 2005 | 02:14 PM
Mr_CRX's Avatar
Default Re: OBD2 B18C(R) EF RUNNING CAN IT RUN OBD1 (gato5254)
You have to do an obd0-obd1 conversion on the EF.
It basically involves getting an obd0-obd1 conversion harness and hooking up a few wires, since you already have the obd1 distributor, o2 sensor, and ecu.
Check out http://www.rywire.com if you arent up to doing the wiring yourself. Ryan is a good guy and has great harnesses. Good luck
Old May 3, 2005 | 02:35 PM
gato5254's Avatar
Default Re: OBD2 B18C(R) EF RUNNING CAN IT RUN OBD1 (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">You have to do an obd0-obd1 conversion on the EF.
Check out http://www.rywire.com if you aren't up to doing the wiring yourself. Ryan is a good guy and has great harnesses. Good luck </TD></TR></TABLE>
no i don't have the obd1 distributor, o2 sensor. I just have p28 ecu, and the the harness that lets you use a obd 1 ecu on a obd 2 motor it's a adapter harness. or some thing like that.
Old May 3, 2005 | 02:37 PM
Mr_CRX's Avatar
well if you have an obd2 distributor, its the same thing as an obd1, just has a single plug instead of the two plugs like obd1
Old May 3, 2005 | 02:49 PM
gato5254's Avatar
could you explain it a little better I don't understand
Blue Hybrid
53
May 1, 2018 09:42 PM
Charleetuner
Oct 3, 2012 07:39 PM
anthony garces
Sep 2, 2009 08:25 PM
Wii Love My SVT
Dec 9, 2007 06:46 AM
mugenintegra16
Apr 8, 2004 10:26 PM
