First gen CRX question, need advise!
Old May 3, 2005 | 01:31 PM
Yak BallZ's Avatar
Default First gen CRX question, need advise!
I am getting my hands on an 87 CRX si, for 300 dollars! I was wondering what would be my best option, in this situation? I was thinking sine i have a sohc d16, out of my 89 si CRX, i could turbo it and swap it into the 87. Is this possible? Or should i get a b20, non-vtec motor? which was my second thing i was thinking about? Or third should i get a dohc ZC and turbo it?
Please tell me what you think. and what you have seen done.
And, i dont care about power steering, or a/c.
Also, what will i need in these swaps.?
Old May 3, 2005 | 01:33 PM
Yak BallZ's Avatar
Default Re: First gen CRX question, need advise! (CRAPanese760)
up!
Old May 3, 2005 | 02:08 PM
Yak BallZ's Avatar
searched, but no cigar! if someone can direct me to a link or just post a how too or any info, please do so
Old May 3, 2005 | 02:31 PM
civicflow's Avatar
A 86-87 integra motor would be the easiest to swap in, everything else you will need custom mounts,axles,wiring all that *****. If you got the money go for a b series motor, hasport makes motor mounts for a b series into an first gen crx. Try searching first gen crx or something like that, the info is out there.
Old May 3, 2005 | 02:57 PM
imgonnalie2u's Avatar
i am a previous owner of a 87 crx u are going to elimanate the entire wiring har ness and modify the mounts that would be the easiest and cheapest good luck
Old May 3, 2005 | 03:12 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
red
pepper
racing
stan
Old May 3, 2005 | 07:03 PM
Yak BallZ's Avatar
Default Re: First gen CRX question, need advise! (Stan D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D &raquo;</TD></TR><TR><TD CLASS="quote">red
pepper
racing
stan</TD></TR></TABLE>
what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflow &raquo;</TD></TR><TR><TD CLASS="quote">A 86-87 integra motor would be the easiest to swap in, everything else you will need custom mounts,axles,wiring all that *****. If you got the money go for a b series motor, hasport makes motor mounts for a b series into an first gen crx. Try searching first gen crx or something like that, the info is out there.</TD></TR></TABLE>
what motor is that? is it dohc? or single cam? and are there compatible turbos?
Old May 3, 2005 | 07:43 PM
jeff420's Avatar
http://www.redpepperracing.com
Old May 3, 2005 | 08:25 PM
Yak BallZ's Avatar
Default Re: First gen CRX question, need advise! (jeff420)
cool, thanks
Old May 3, 2005 | 09:09 PM
civicflow's Avatar
if you didn't read about it, the 86-87 integra motor is dohc, t25 or any small type turbo would be good to start out with. Not sure about the turbo manifold itself though.
Old May 4, 2005 | 08:32 AM
Yak BallZ's Avatar
Default Re: First gen CRX question, need advise! (civicflow)
thanks, anything else you guys can think of? is the 86 integra motor a zc?
Old May 4, 2005 | 09:12 AM
civicflow's Avatar
you could call it the american ZC but it is totally different from jdm dohc/zc, it has around 115hp(around there), it is kinda like dropping a jdm ZC into a 88-91 civic/crx in that it is mostly plug and play, but you should only use the 86-87 integra motor as the 88-89 motor uses a different type of speed sensor(not sure on the type of sensor but it would be easier to use the 86-87 motor).
Old May 4, 2005 | 09:17 AM
civicflow's Avatar
https://honda-tech.com/zerothread?id=1132312
that shows an integra motor in a first gen crx
check out the red pepper racing site
Old May 4, 2005 | 10:41 AM
Smokinsax's Avatar
The Boot
pm'd
Old May 4, 2005 | 01:07 PM
Yak BallZ's Avatar
Default Re: (Smokinsax)
thanks for all the input guys. if theres any more info, please feel free to let me know.
Old May 7, 2005 | 05:53 AM
jeff420's Avatar
Default Re: (CRAPanese760)
its not the speed sensor that makes it hard. 86-87 motors are vacum advance and 88-89 are electronic
Old May 8, 2005 | 01:11 AM
civicflow's Avatar
Default Re: (jeff420)
yes, thats it, 420 da man
G-Auto*Hero
Aug 4, 2011 03:15 PM
crx_si_mike
Classic Hondas
Jun 23, 2009 05:53 AM
crxzcracer
Dec 6, 2004 09:23 AM
I8ayellowcrayon
Jun 18, 2003 10:11 PM
DV98CVC
Aug 22, 2002 06:52 PM
