Need help with 93 dx civic hatchback
My problem is that my 93 Civic will not start. It will trun over all day, but when it comes down to starting the motor it will not happen. It first started by when i was driving the car it would start acting like it was getting little gas, and it would cut off. But it would start back up with out a problem and it would be fine for a while, then it would do it agin. Then one day i was driving it cut off and it would not start back up at all. So with in the last week i have spent about 500.00 in parts. and nothing seem like its working. Their for i have replaced the parts as listed.... Spark plugs(NGK-> gap is at .039) and wires and cap, disturbtor(houseing and all), map sen,O2 sen, Main relay, fuel filter,fuel pressure regaltor.
I really don't know that much about hondas and all so plz tell me what in the hell i'm i doing wrong.
Supermaninsatl
Supermaninsatl
check your codes to see if there are any.the procedure can be found at the top of the forum.
you've replaced a lot of stuff.possibly the fuel pump,although in my experience it fails once and doesn't work again.
Chris
Chris
boostedbc
17
Jun 6, 2013 09:48 AM
93civicdriver
10
Sep 16, 2010 11:45 AM
niccuhles
May 26, 2004 09:58 AM
