What NGK spark plugs do i use for boosted B18C1??? Need to make sure sure I got the right ones....
I just picked up some NGK Platinum plugs, part#PFR6Q 6458. Is this the right one? Also what should I gap them to for 7lbs of boost???
Either ngk stock number 1095 (bcpr7es11) stock colder plug / or number 6097 (bkr7e) Split fire cold plug
Depending on the boost you are running and what ignition you have set up and how rich it is during cruise and idle, I would suggest about .28 if you run 12:1 under load and 14-13:1 during cruise. That generally works out pretty good!!
Shark Tank
Apr 29, 2003 06:43 PM
