Debating on what motor i should put in.....
Old May 3, 2005 | 02:04 AM
HonduhRex's Avatar
Default Debating on what motor i should put in.....
What's up to everyone at H.T
Im a n00b here so yeah, spare me lol
I recently got a 89' honda CRX from a friend of mine for $300,
when i first got it, it ran like **** to be honest
so on my spare time i did a few things, one of my problems were
when i start up the car and throw it into drive [yes its automatic ]
the car suddenly cutts off....so when i popped the hood and looked carefully
i noticed that one of those small hoses going to the MAP sensor have been torn off
so i went to a local junk yard and get a set of hoses, and when i got home i replaced them.....when i was done with everything it started up fine, and it actually drove good [for a POS TBI engine] w/ no check engine light...so i got that out of the way.......right now the car is sitting infront of my house, i have stripped out everything inside of the car and cleaned what was under the carpets, what i have now in my crx is just the 2 seats [which i plan on changing soon] , the dash, and and the steering wheel, i removed my radio and i plann on mounting my gauges where my radio used to be [ boost, a/f, volt, etc] I plan on taking the car to a local body shop to repair the rust on the rear qtr panels, since its in bad shape and i cant do body work for ****.... while the body work is underway, i was debating with a friend of mind on which motor shoud i drop in? I've seen guys on here with h22a-T CRX's .......i plan on doing the same, if it can happen.....but im not really sure because a setup like that would mostly be for straight line....and the car would understeer ALOT...... Im here for open opinions.....since im new to this honda scene , any help from you guys would be great .......thanks alot guys!
what motor should i put in?
-B16a1?
-B18c1?
-B18b1-T [block with a b18c1 head]
-H22a
Old May 3, 2005 | 02:47 AM
CRX_Control's Avatar
Default Re: Debating on what motor i should put in..... (HonduhRex)
go d series vtec
Old May 3, 2005 | 03:38 AM
Snaps's Avatar
Default Re: Debating on what motor i should put in..... (CRX_Control)
Deff. not H22, I'd say B16 for price. Just my opinion though, I haven't owned a rex in a while .
Old May 3, 2005 | 04:02 AM
civic_jdm's Avatar
i would say boosted sohc vtec!!!!
Old May 3, 2005 | 04:04 AM
CRXCrazy123's Avatar
id say go with the b18b1 - t just for the all around get around car and to have somefun
Old May 3, 2005 | 04:08 AM
Default Re: (civic_jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_jdm &raquo;</TD></TR><TR><TD CLASS="quote">i would say boosted sohc vtec!!!!</TD></TR></TABLE>
lol bosted and v tec right just not sohc, but dohc
Old May 3, 2005 | 06:28 AM
soulrider4ever's Avatar
Default Re: (CRXCrazy123)
always been a fan of the b18c1 or c5 if u can afford it!
Old May 3, 2005 | 02:11 PM
civic_jdm's Avatar
boosted single cams are good.......Parts and motors are a dime a dozen.....alot cheaper to replace when it blows!!!!!!!!!!!
Old May 3, 2005 | 02:16 PM
CRseXy's Avatar
d15b vtec
Old May 3, 2005 | 03:25 PM
ImportHatch's Avatar
Default Re: (pogiTSI)
turbo z6 or y8. Can't beat the price.
Yager-
Old May 3, 2005 | 03:29 PM
stdefhatch's Avatar
B16 is easy and fun
Old May 3, 2005 | 03:46 PM
doublethink's Avatar
if youve never swapped before might be a good idea to start with something like a d16a6 swap and auto to manual conversion.
get you started off on the right foot. (pun)
if you can afford a b16a it really is a lot of fun, thats what i currently have in the rex. it will run you about 2300-2500 to get it into the car with all the stuff you need.
Old May 3, 2005 | 03:55 PM
Bjorn20's Avatar
depends how much money u wanna spend, if u wanna go all motor or not. a great all motor engine is ls vtec. b16a a good starting engine if u dont have a ton of money to spend
Old May 3, 2005 | 04:19 PM
HonduhRex's Avatar
Default Re: Debating on what motor i should put in..... (Bjorn20)
Yeah a friend of mine has a single cam Vtec turbo.....that thing was quick for a single cam.........but yeah I do plan on doing the auto-to-manual conversion, when the warm weather hits......and money isnt an issue.......im pretty sure i can get the B18c1, in order to drop that in do i have to do any welding, banging,cutting???
and i do plan on tuboing the b**ch[t3/t4]...... im going to have pics of my CRX
posted soon and show u guys what my $300 CRX looks like...
And another thing.....the ls/V[turbo] doesnt sound like a bad idea either......and ive heard that the LS block is good for a turbo application,
Old May 3, 2005 | 06:26 PM
HatchBox's Avatar
Skoobie no more...
hemi
Old May 3, 2005 | 07:33 PM
93formula's Avatar
Default Re: Debating on what motor i should put in..... (HatchBox)
lol, "yeah its got a hemi"
BarcodeCRXSI
27
Feb 16, 2011 12:54 PM
Evs-One
Sep 19, 2006 07:59 AM
Reelizmpro
18
Sep 4, 2005 02:48 PM
vg7z
Jul 20, 2005 11:16 AM
Jaysmy
Jul 23, 2001 09:16 PM
