LOOKING:Switch Panel
im looking for a swtich panel,. it must at least 5 switches, this is all i found so far.. any one?
http://www.centechwire.com/cat...shtml
If you know enough about wiring to integrate one of those into your car, then you know enough about wiring to make your own.
Switches, led's, fuses, etc. max $15 at RadioShack plus some sheet metal.
I am running a moroso 5 rocker switch panel with a momentary start switch. The 5 switches are re-setable by having 20 amp circuit breakers. Very nice setup. No need to run a fuse block. And if you aren't running much like I am, it is very easy to wire up, and there is no clutter at all. For my 5 switches, they control ignition, fuel pump, water pump, radiator fan, and lights. Here is how it looks
Its not that hard to make one yourself and it'll be even cheaper not to mention you'll get to mount everything right where you wanna put it! Just wait till your completely bored shitless one day and rig one up.
