exedy OEM clutch kit with fidanza 7.5lbs
how well will a OEM replacement clutch kit by exedy work with a fidanza lightweight? cause im thinking about getting this kit which comes with both for $$299. is it neccessary to get a stage1 or its not ?
will an exedy oem grip just fine or will the lighter flywheel need the extra grip of the stage 1 ? and also would it be smarter just to go stage 1 at the same time or do you guys think its not neccessary. this is going to be a daily driver with a couple of runs every once and a while.
ok thanks but one more question, does the exedy oem clutch grip better than the oem honda clutch or just as equal? and would the exedy stage 1 be worth the extra money do you think?
i got me exedy racing stage 1 clutch and fidanza 7.5lb fw.. love it, you can feel the difference comparaed to oem clutch.. clutch feels very light.. my suggestion is go with stage 1 if your not planning on adding some serious power..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg »</TD></TR><TR><TD CLASS="quote">ok thanks but one more question, does the exedy oem clutch grip better than the oem honda clutch or just as equal? and would the exedy stage 1 be worth the extra money do you think?</TD></TR></TABLE>
daikin exedy is the company that makes the clutches for Honda. Honda sells Exedy clutches. therefore, feel, grab, durability, reliability, etc. will all be stock/Honda/OEM.
ninjarich2
Jun 19, 2009 04:51 AM
