weird exhaust sound at idle...
Old May 2, 2005 | 07:22 PM
Creepshow S60's Avatar
Default weird exhaust sound at idle...
first off, i'm going to simply assume this is a timing issue. during idle, it sounds like my exhaust is "bubbling". kinda like how a big v8 with lumpy cams idles...blub blub blub blub. i guess that's kinda an ok description...?
thing is, i'm not sure (if it IS the timing)...how the timing is off. I never made any changes, so maybe you guys have some opinions.
i'm having trouble with emissions (HCs for idle), and everybody says to make sure before emissions that the timing is at the stock setting. i assume this issue is timing related, and therefore causing me to fail emissions. makes sense to me.
i don't have the timing belt cover over the cam gear, so i have nothing to really go by as far as setting it to stock. is there another way i can do this? i know the pistons have to be at TDC correct?
searched for this and found one thread under "bubbling exhaust", and mostly everybody replied with exhaust leak information. found many threads on setting the timing, but i'd like to make sure this is a good area to start with before doing any work.
suggestions anybody?
Old May 2, 2005 | 07:25 PM
CRX_Control's Avatar
Default Re: weird exhaust sound at idle... (y-49CRX)
i think that means its detonating , so retard your timing some by turning the distributor away from the firewall . Hope that helps .
Eric
Old May 3, 2005 | 07:58 PM
bump for more opinions...
Old May 3, 2005 | 08:15 PM
CRseXy's Avatar
Default Re: weird exhaust sound at idle... (CRX_Control)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">i think that means its detonating , so retard your timing some by turning the distributor away from the firewall . Hope that helps .
Eric </TD></TR></TABLE>
Possible, Its probly a miss. Id adjust the timming also, with a timming light. theres a howto on here somewhere. When was the last time you changed your plugs and wires????
Old May 3, 2005 | 08:49 PM
d16efsedan's Avatar
Default Re: weird exhaust sound at idle... (pogiTSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y-49CRX &raquo;</TD></TR><TR><TD CLASS="quote">first off, i'm going to simply assume this is a timing issue. during idle, it sounds like my exhaust is "bubbling". kinda like how a big v8 with lumpy cams idles...blub blub blub blub. i guess that's kinda an ok description...?
suggestions anybody?</TD></TR></TABLE> i would also like to know mine does the same thing from time to time......
Old May 3, 2005 | 09:09 PM
doublethink's Avatar
get the piston to top dead center then with the belt off line up those cam gears, reconnect the belt, do your tensioner but back the valve cover.
done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">i think that means its detonating , so retard your timing some by turning the distributor away from the firewall.
this is 100% correct. you can adjust it with the dizzy too, once the other side is 100% stock...
gooblinn258
Dec 12, 2013 06:21 PM
Ran4it2
Jun 27, 2007 12:52 PM
95vtecsrus
Feb 3, 2005 07:40 PM
enasnidx
Dec 28, 2004 03:09 PM
civicracer1993
Jan 24, 2003 07:48 PM
