Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Is Jet Hot coating a header HC H1 legal?
Old May 2, 2005 | 03:53 PM
NirVTEC's Avatar
Default Is Jet Hot coating a header HC H1 legal?
I just want to make sure I do everything right the 1st time. I would hate to JHC my $900 TODA header if its illegal.
Old May 2, 2005 | 04:10 PM
chad's Avatar
Moderator
Default Re: Is Jet Hot coating a header HC H1 legal? (NirVTECn2o)
why jet coat it.....it won't help....and i sure wouldn't do it to a toda header!
Old May 2, 2005 | 04:16 PM
NirVTEC's Avatar
Default Re: Is Jet Hot coating a header HC H1 legal? (chad)
You dont think it'll lower underhood temps? Are their claims all hogwash?!?! I am also thinking of the oil pan temps.....
Old May 2, 2005 | 05:11 PM
D.CACO's Avatar
You can do it if you want.
Old May 3, 2005 | 04:34 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Is Jet Hot coating a header HC H1 legal? (D.CACO)
Non-sticky heat wrap if you're just worried about underhood temps? And whereabouts are you racing? On the East Coast I've never had problems with overheating or anything.
Old May 3, 2005 | 04:58 AM
Track rat's Avatar
Default Re: Is Jet Hot coating a header HC H1 legal? (sscguy)
If you are worried about heat transfer into the oil pan, just cover that portion of the pan with some heat barrier cloth.
Old May 3, 2005 | 12:42 PM
Geezer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NirVTECn2o &raquo;</TD></TR><TR><TD CLASS="quote">You dont think it'll lower underhood temps? Are their claims all hogwash?!?! I am also thinking of the oil pan temps.....</TD></TR></TABLE>
When I put a mild steel header on my wife's MG Midget, I had it coated as much to prevent rust as anything else. This was about 5 years ago and it still looks like the day I put it on, inside and out. The BMC A-series engine has the intake and exhaust on the same side of the head, and is sometimes prone to vapor lock. The coated header eliminated this problem and noticeably reduced the underhood temp.
Since then I've always had my headers coated. Doesn't cost that much, makes the header last longer, and getting more heat away from the engine can't hurt.
Old May 3, 2005 | 01:38 PM
Suspetise...
Default Re: Is Jet Hot coating a header HC H1 legal? (Geezer)
Toda header is SS though, not mild steel.
Dave_B
Jul 14, 2006 08:09 PM
slow91crx
Welding / Fabrication
Jun 7, 2006 06:07 AM
RTW DC2R
Apr 5, 2006 07:51 AM
Pompiuses
Mar 1, 2005 10:14 AM
Shakes
Mar 28, 2004 07:25 AM
