T-3 60 Trim Compressor .48 A/R achieve boosting at what RPM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">.48 is a small housing, you should have full boost by 3k</TD></TR></TABLE>
Nope
Nope
Yeah I'm guessing full boost should be at around 3600-3900 or so depending on what else you have. 1.6L engines aren't flowing enough to spool that early.
I'd get an aftermarket manifold. One of those spoolinperformance (I think he does d series?) log manifolds or something similar should do nicely.
You can always swap a .63 housing onto it later if you want. People sell them used all the time, and a turbine housing can't really wear out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin »</TD></TR><TR><TD CLASS="quote">You can always swap a .63 housing onto it later if you want. People sell them used all the time, and a turbine housing can't really wear out
so i could use a 63 housing from a t3 t4
</TD></TR></TABLE>so i could use a 63 housing from a t3 t4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Mine spools by 3k on my 1.8 liter Miata. I do have the .42 compressor housing and .48 turbine housing</TD></TR></TABLE>
My LS with my 42/48 start to spool up practically off idle and probably full boost under 3k.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Hooligan »</TD></TR><TR><TD CLASS="quote">
so i could use a 63 housing from a t3 t4</TD></TR></TABLE>
Yup.
Yup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt »</TD></TR><TR><TD CLASS="quote">Mine Starts pulling around 2800-3000, an full boost around 4000 (10psi)</TD></TR></TABLE>
same here
same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt »</TD></TR><TR><TD CLASS="quote">Mine Starts pulling around 2800-3000 an full boost around 4000 (10psi)</TD></TR></TABLE>
Same here...
I usually don't see positive pressure until 3400 or so, but I can hear is start spooling before that.
Same here...
