Analysis of Plug... how's my motor doing???
Old May 2, 2005 | 03:50 PM
Mario.'s Avatar
Default Analysis of Plug... how's my motor doing???
Ok, so along with a new cap and new rotor, I changed the plugs. The pictures are a 1 step colder NGK plug gapped to .030 on a 6psi turbocharged b16a. At the dyno, I had a bunch of misfires and I'm not sure if it's fixed... the car seems to pull a lot better, but feels like it needs tuning to reach it's maximum. These plugs have seen:
A 1-2 gear WOT run. Followed by a 3rd gear 3,000rpm pull to redline and that is it.
Old May 2, 2005 | 03:55 PM
Soccerking3000's Avatar
Default Re: Analysis of Plug... how's my motor doing??? (Mario.)
see how its white was it running lean?
Old May 2, 2005 | 03:56 PM
Mario.'s Avatar
Default Re: Analysis of Plug... how's my motor doing??? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">see how its white was it running lean?</TD></TR></TABLE>
It's pretty far from lean AFAIK...
This is the dyno for the settings the car is running right now.
Old May 2, 2005 | 04:00 PM
fastrunner's Avatar
you should be running 7's not sixes in a turbo car, BKR7's are what you should have but the gap is right. What kind of fuel management are you using, its a turbo car, your plug tips are gonna be a lil white, it wont run the same way as an NA car will, but a low"er" compression headgasket will also keep that from happening.
Old May 2, 2005 | 04:11 PM
Mario.'s Avatar
Default Re: (fastrunner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrunner &raquo;</TD></TR><TR><TD CLASS="quote">you should be running 7's not sixes in a turbo car, BKR7's are what you should have but the gap is right. What kind of fuel management are you using, its a turbo car, your plug tips are gonna be a lil white, it wont run the same way as an NA car will, but a low"er" compression headgasket will also keep that from happening.</TD></TR></TABLE>
I did have the 7's... two step colder is an overkill.
AFC plus 450's plus Walbro. Tried tuning with Uberdata but the car made no power with it since the ignition was all fucked.
I am just asking if that looks normal or not... I don't know what it's supposed to look like.
Old May 2, 2005 | 04:23 PM
Archidictus's Avatar
Unceasing Measure
I don't see any pitting or cracking in the porcelain, so I'd say you're probably pretty fine. The black residue is good because it means you're getting a decent amount of fuel burn.
The only thing that might concern me is the side of the ground strap (thanks dude ) that seems to have some flaking. That's not completely abnormal, but I'd check all my other plugs to make sure it's not any worse on the others.
Modified by Archidictus at 12:30 PM 5/3/2005
Old May 2, 2005 | 05:20 PM
fastrunner's Avatar
yah looks normal, my plugs look like that but I do run 7's as most people, I think 6 is the stock, but I could be wrong.
Old May 2, 2005 | 06:11 PM
LShatchie's Avatar
Your plugs look good to me, as long as they are a nice tan.. my monitor is kinda messed up so its hard to tell the color.
Old May 3, 2005 | 05:04 AM
Mario.'s Avatar
Default Re: (LShatchie)
Thanks guys. They actually look a bit more white than tan... I think I may need to retard the timing a couple degrees.
BTW, I think the 6's are one step colder, and the 7's are two step colder.
Old May 3, 2005 | 05:08 AM
Bimmerman's Avatar
Default Re: (Mario.)
ngk is backwards going up a number mean going down in heat
Old May 3, 2005 | 05:19 AM
siblueg's Avatar
Default Re: (Bimmerman)
6 is the stock heat range, 7 is the right choice. your car only made 150-160 hp?
Old May 3, 2005 | 06:00 AM
Mario.'s Avatar
Default Re: (siblueg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblueg &raquo;</TD></TR><TR><TD CLASS="quote">6 is the stock heat range, 7 is the right choice. your car only made 150-160 hp?</TD></TR></TABLE>
Yep, I was having some major misfires up top and I think it had some major side effects... car makes no power past 5,000rpm. I need a better tune.
Old May 3, 2005 | 08:15 AM
Turbo E's Avatar
i see tiny specs on the porcelin...i hope its no aluminum.
Teamdiesel
30
Nov 13, 2007 03:38 PM
USDM-EK4*
Oct 21, 2007 06:35 PM
mike93eh
Apr 8, 2005 02:04 AM
RTW DC2R
Mar 13, 2004 09:34 PM
Spade
39
Nov 20, 2003 12:34 PM
