pw0 and pr3
Old May 2, 2005 | 01:47 PM
MessGSR's Avatar
Default pw0 and pr3
i just did my b16a swap in my crx...and my red line with my pwo 5spd is only 7200. when my buddy has a ef hatch with same motor but pr3 and he revs to 8200? i did hook up a vfac... but shouldent my rev limit on the pwo be 8200 also?
Old May 2, 2005 | 02:02 PM
Rywire's Avatar
Default Re: pw0 and pr3 (MessGSR)
Do u have any codes? That could be why.
Old May 2, 2005 | 02:12 PM
KFBhonda's Avatar
Default Re: pw0 and pr3 (droppedcrxsi)
codes will make your redline lower. or a cold engine. let it warm up and try each ecu. a knock sensor code on my pr3 won't let me into the vtec upper lobe, and puts my fuel cutoff (redline) at about 7000, but my pw0 lets me into vtec and keeps the 8200 rpm redline, while throwing the same code.
Old May 3, 2005 | 11:17 AM
CLK-EF's Avatar
Default Re: pw0 and pr3 (KFBhonda)
yep. this seems to be the case for me too. my pw0 ecu takes longer to be happily warmed up vs my pr3 that doesn't seem to give a rip. needless to say, i use the pr3 at autoX. but for some reason, the pw0 seems peppier.
b
#1 overall and pax
SM 063 - 91 EF hatch
http://www.sccahawaii.org/S2Race2.html
Old May 3, 2005 | 03:04 PM
MessGSR's Avatar
Default Re: pw0 and pr3 (CLK-EF)
i had a 22 code which on a jdm ecu is onli pressure sensor...which turned out to be a loose wire in the connector.....i took my ecu and put it into a another jdm b16 and hwe was able to redline right to 8200....i think it could be my jdm cluster? bvecuase i threw a VSS code when i firt ran the motor which turned out to be, the vss was hooked up wrng, and my tach goes right to 3000 rpm on startup and never drops? any ideas thanks
Old May 3, 2005 | 03:14 PM
SETI20's Avatar
I love your new avatars
Seems that one type of ECU decides to lower the redline based on other conditions that others.
I've never been abe to fully determine what wiil, and what will not affect these decisions.
Old May 3, 2005 | 04:17 PM
MessGSR's Avatar
Default Re: (SETI20)
also could there be a problem with the hasport wiring harness or my wiring?
Old May 4, 2005 | 01:41 AM
SETI20's Avatar
If it works with one ecu and not with the other, it's higly unlikely that it's your wiring.
Old May 4, 2005 | 09:05 AM
Rywire's Avatar
Default Re: (MessGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MessGSR &raquo;</TD></TR><TR><TD CLASS="quote">also could there be a problem with the hasport wiring harness or my wiring?</TD></TR></TABLE>
Nope, i really dont think so man
Old May 4, 2005 | 10:49 AM
Nerologic's Avatar
Default Re: (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">I love your new avatars</TD></TR></TABLE>
x2
Old May 4, 2005 | 11:25 AM
DocSean's Avatar
Is it an automatic or manual ECU? I had an automatic PR3 and it had the lower redline.
Old May 4, 2005 | 12:40 PM
EFRue57's Avatar
Default Re: (spankjelly)
My brother had the same problem until we hooked up a knock sensor. do you have your knock sensor hooked up? if not that could possibly be it. after we installed and hooked it up it went to 8200.
Old May 4, 2005 | 02:05 PM
MessGSR's Avatar
Default Re: (EFRue57)
it ia m/t ecu any one know the pin number for the knock sensor at the ecu i may have it pined wrong
Kenzo206
15
Nov 9, 2008 06:57 AM
Scott - 93HB Si
Feb 20, 2004 11:17 AM
91 SlEePeR
Apr 9, 2003 05:02 PM
