H22 ground clearance
Old May 2, 2005 | 01:30 PM
SIcivicHATCH's Avatar
Default H22 ground clearance
I am looking to put a h22 in my eg hatch. Any pics of ground clearance and also post your lowering numbers
thanks
Old May 2, 2005 | 01:33 PM
IHateJDM's Avatar
Default Re: H22 ground clearance (SIcivicHATCH)
Lowered about 2" on coilovers. I have 3.25" of clearance for the oil pan.
Edit: my web server is currently down, i'll check on the pic later.
Old May 2, 2005 | 01:47 PM
alleyezonme's Avatar
Default Re: H22 ground clearance (IHateJDM)
coilovers don't know the drop... PLENTY of room, more then to worry about
Old May 3, 2005 | 12:16 AM
Default Re: H22 ground clearance (alleyezonme)
seen a guy yesterday with a h22 in his civic and he was only lowered about an inch and his oil pan was a good 1.5-2" from the ground
Old May 4, 2005 | 06:50 AM
EgRedSi's Avatar
You can slam it just like any other engine, just get really stiff springs and run 16's. That'll keep the oil pan a good 5 inches off the ground.
Old May 4, 2005 | 06:59 AM
IHateJDM's Avatar
Default Re: H22 ground clearance (EgRedSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgRedSi &raquo;</TD></TR><TR><TD CLASS="quote">You can slam it just like any other engine, just get really stiff springs and run 16's. That'll keep the oil pan a good 5 inches off the ground. </TD></TR></TABLE>
Look at the pic above, I'm on 16's and I have 3 1/2" max. Its really not a big deal though, I just have to go slow in and out of parking lots.
Old May 4, 2005 | 07:26 AM
EgRedSi's Avatar
My boy has one, he's running 205/45/16's. The body isn't really slammed on the tires, it's right above it and he doesn't have any problems. He's high enough to put a VIS lip on it and not worry about scrapping.
Old May 4, 2005 | 07:30 AM
IHateJDM's Avatar
Mines on 205 45 16's too. I have about enough gap to stick my thumb between the tire and fender, and that's all. I'm about to make myself a home depot lip, and we'll see how long that lasts. I pretty confident I'll crack it quickly, which is why I won't spend much money on one.
Old May 4, 2005 | 07:38 AM
EgRedSi's Avatar
I agree. I'm just saying that it's possible. I wouldn't do either.
LShatchboy
Sep 6, 2007 04:20 PM
crj_lll
Apr 15, 2006 01:52 PM
RichIt Strike
Mar 15, 2006 05:53 PM
djnikko
Feb 16, 2006 04:54 AM
high_revs
Sep 23, 2005 10:33 AM
