Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Help, cant intstall front arp wheel studs in my teg
Old May 2, 2005 | 11:29 AM
dAng! Kris's Avatar
Default Help, cant intstall front arp wheel studs in my teg
I can't for the life of me get the hub off to change out the wheel studs. I've searched and searched but have found little to no help. If someone could lemme know how do do it, It'd be great. Thanks
Old May 2, 2005 | 11:32 AM
keithv's Avatar
Default Re: Help, cant intstall front arp wheel studs in my teg (Frozty)
This thread should help. I know it helped me out!
https://honda-tech.com/zerothread?id=720159
to Willard!
Old May 2, 2005 | 11:34 AM
Todd Reid's Avatar
to remove the front hubs, you must remove the knuckle. then get a big press, and press out the hub. then press out the bearing from the knuckle. most times the bearing comes apart and a piece of the race will jam on the hub. you need to get that off, too. sometimes requires heating with a torch.
then you can press or pound out the old wheel studs, and press or using washers and a open end lug nut pull in the new arp studs. then press the new wheel bearing into the knuckle. i froze my bearing first and gently warmed the knuckle so it would go in easy. be careful only to press on the outside race, or you will wreck the bearing.
then press the hub into the bearing. once again be careful to support the inner race this time or you will wreck the bearing.
have a fun day!
todd
Old May 2, 2005 | 11:38 AM
dAng! Kris's Avatar
WOW, Thanks for the quick replys
Old May 3, 2005 | 03:51 AM
Mattamotor's Avatar
I use a Slide hammer to get mine off. That way you dont have to remove the Knuckle.
ef90b16
Nov 28, 2008 09:36 PM
boun4door
Oct 1, 2008 03:32 PM
SomeGoodBud2
Suspension & Brakes
Mar 18, 2007 02:48 PM
9seccivicsi
Feb 11, 2004 06:07 AM
EK MONEY
Nov 2, 2002 05:47 PM
