noise from timing belt
i've did a search and this was the closes topic i found. i just wanted to verify since the post was rather old.
https://honda-tech.com/zerothread?id=627657
according to this post, when changing the timing belt, water pump, ac belt, etc., it takes 2 weeks to a month for the squealing to go away. is this true?
i just changed it yesterday and every time i start up the car when it has been sitting there for a few hours, it squeals for a few seconds and then it is fine after that. should i be concerned? after the few seconds of squealing, you can barely hear anything abnormal. i changed all the belts, water pump, and a few seals on a 97 accord ex (automatic). someone please help. i'm paranoid right now to start my car up. thanks in advance!
From: Filthadelphia City of Brothers and Love, PA, USA
This is not normal and it may not go away by itself. The last time I had my belts changed my car did that for weeks afterward. When I took it back for another service I was scheduled to have performed I complained and they said no problem. I don't know what the fix was, but they got it to stop that day. I know I tightened the alternator belt and it did not help at all. I also checked the PS pump belt and it was also nt the problem. I believe it may be an issue with the timing belt tensioner.
schmitey you heard right it will shreak if balancer belt and or timing belts are too tight ,, i would loosen up adjuster nut and readjust t-belt..and make sure outer belts are not loose
i don't know if this would help, but i noticed that when i turn on the a/c while the engine is turned on, it does make that squealing sound. could the a/c belt be the culprit?
JDQuikZ6
Honda Civic (2001 - 2005)
May 2, 2010 12:26 PM
B18CYAAA
Aug 3, 2009 07:13 PM
vltnolia
Jun 28, 2008 09:54 PM
