ford t3 downpipe gasket where can i buy one?
Old May 2, 2005 | 10:00 AM
staticchmbr's Avatar
Default ford t3 downpipe gasket where can i buy one?
WTB: ford t3 5 bolt downpipe gasket. i put a turbo kit on my crx yesterday, and i need a new gasket. this one is leaking pretty bad. i need the ford 5 bolt downpipe gasket, and i called around to different ford dealers, but they dont have them. where can i buy one of these??
the turbo is off of an 86 thunderbird turbocoupe .48/.60 ar t3
Old May 2, 2005 | 10:51 AM
Default Re: ford t3 downpipe gasket where can i buy one? (staticchmbr)
up
Old May 2, 2005 | 10:52 AM
rmcdaniels's Avatar
Nobody I know runs a gasket there, including me. Red Permatex gets the job done on my Ford 5-bolt turbine outlet. There's no pressure there, so a gasket isn't needed, just a bit of sealant to keep it from leaking.
Old May 2, 2005 | 11:08 AM
notoriousB's Avatar
Default Re: ford t3 downpipe gasket where can i buy one? (rmcdaniels)
agreed - I actually don't even use RTV. If your flange surfaces are flat they will not leak. Take the gasket out and bolt 'er up!
Old May 2, 2005 | 11:22 AM
dustin's Avatar
Yeah I've had bad luck with the DP bolts backing out when using a gasket. Just bolt it directly to the turbine housing. If it is leaking that much, your DP flange is warped etc.... resurface it (I've done this before with a belt sander, wear gloves!).
superslow-oto
Oct 14, 2007 02:35 PM
Johnny_Rocket
Jun 30, 2005 06:10 PM
pushinlsteg
May 19, 2005 08:15 PM
staticchmbr
May 2, 2005 10:51 AM
DaX
Apr 4, 2005 08:34 AM
