Apexi Grounding Wires
Old May 2, 2005 | 09:47 AM
JDM4DRACCORD's Avatar
Default Apexi Grounding Wires
I have the Apexi Grounding Wires. There are two built into the unit, they are for the battery. Then there are three wires that bolt up to the unit. My question is where do i bolt up the three wires at? What do I bolt them down to. Please help me thanks.
Old May 2, 2005 | 11:12 AM
Default Re: Apexi Grounding Wires (JDM4DRACCORD)
Do any of you have Apexi Ground Wires?
Old May 2, 2005 | 01:47 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM4DRACCORD &raquo;</TD></TR><TR><TD CLASS="quote">I have the Apexi Grounding Wires. There are two built into the unit, they are for the battery. Then there are three wires that bolt up to the unit. My question is where do i bolt up the three wires at? What do I bolt them down to. Please help me thanks.</TD></TR></TABLE>
No instruction??? Try apexi website for tech support.
Old May 2, 2005 | 08:25 PM
No luck there. I was hoping an Accord Brother could help me out.
Old May 3, 2005 | 03:11 PM
Anyone? Anyone Have An Idea?
Old May 3, 2005 | 03:57 PM
accordselux's Avatar
Me Gusta History
You bolt them at key points on the chassis. To get the most out of them, you run the car on a dyno and try different points.
Old May 3, 2005 | 05:30 PM
fw190bvi's Avatar
Default Re: Apexi Grounding Wires (accordselux)
usualy its onto the frame.......you have factory groundpoints, so if you just use those, you'll be fine....
BTW: this new trial memeber avatar is confusing
Old May 3, 2005 | 05:32 PM
SuShiBoiiii's Avatar
Default Re: Apexi Grounding Wires (fw190bvi)
engine, alternator, and somethin else i forget
Old May 3, 2005 | 05:36 PM
sumptimwong's Avatar
Default Re: Apexi Grounding Wires (SuShiBoiiii)
seems that the best bet is to use factory grounds. use a ground tester with a light (digital readout is even better) to indicate the relative strength of each ground point. otherwise, just bolt up onto any point on the chassis, and make sure theres no paint between the bolt/wire and the frame.
Old May 3, 2005 | 08:01 PM
Cool Ill do What You Said^^^ Ill Grab My Buddies Ground Tester. One More Question, What If There Is Paint On The Box Were The Wires Bolt Up. Will That Affect It?
Old May 3, 2005 | 08:10 PM
pyrojeff's Avatar
Default Re: (JDM4DRACCORD)
Just do engine (valve cover), alternator, and transmission for the three grounds. There are a lot more grounds than those, however.
Old May 3, 2005 | 08:18 PM
^^^ Is That What You Did? Was It Effective?
Old May 4, 2005 | 06:29 AM
THEROPE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM4DRACCORD &raquo;</TD></TR><TR><TD CLASS="quote">^^^ Is That What You Did? Was It Effective?</TD></TR></TABLE>
thats what you do
engine, alt, trans
they are the three main, you can also do the IM, and the starter
but that is extra
and you also want to clean/grind off and rust or corrosion before the you put the grounds on, that will make the signal better
Old May 4, 2005 | 06:43 AM
Me Gusta History
Default Re: (THEROPE)
And get some of that gooey stuff from an auto store and put it on the connections, itll help prevent corrosion. That stuff's by the wires and crimpers, etc. Electrical section.
Old May 4, 2005 | 12:55 PM
Default Re: (accordselux)
gooey stuff? never heard. is this stuff conductive, or insulating? im just concerned that it would tend to insulate the ground, and that would cause problems. if youre really concerned about corrosion, wouldnt a thin layer of paint over the area do the job just as well?
Old May 4, 2005 | 02:02 PM
So does paint affect the grounding?
Old May 4, 2005 | 02:07 PM
nope, as long as the paint isnt BETWEEN the wire/bolt and the frame.
Old May 4, 2005 | 02:41 PM
Cool im in the clear. Thanks for the help fellow Accord owners. Ill post pics in a little while.
Old May 17, 2005 | 03:38 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (sumptimwong)
where on the alternator?
Old May 17, 2005 | 08:15 PM
pyrojeff's Avatar
Default Re: (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">where on the alternator?</TD></TR></TABLE>
On the top. It's just a wire bolted down. Pretty easy to spot.
Old May 17, 2005 | 08:25 PM
General Kenobi's Avatar
i would like to buy a grounding wire kit but can anyone suggest one that is readily available for a good price?
Old May 17, 2005 | 08:37 PM
brads94accord's Avatar
i wouldn't waste my money buying one of those, just buy about 15 feet of 4 guage power wire, some gold plated connectors and crimper, you have yourself a ground wire kit for $20 like me
Old May 17, 2005 | 10:31 PM
He is right^ I should hve done that but oh well
Old May 18, 2005 | 09:44 AM
Turbowa's Avatar
You would be talking about Die-electric compoind. You DON'T want to use this. It will accutally attract current. This is what is use on spark plug wires for a better connection and to keep them from getting stuck on.
p nut
Audio / Security / Video
Jun 22, 2007 11:50 PM
enhancedCL9
Feb 10, 2004 10:51 PM
rs
Sep 22, 2003 07:50 PM
prjctCIVIC
Sep 1, 2002 03:07 AM
