Hose question next to Fuel Filter B16A2
Old May 2, 2005 | 09:26 AM
TheNasty0ne's Avatar
Default Hose question next to Fuel Filter B16A2
There this canister thing right under my battery under the fuel filter.
and theres a hose connected to it heading towards the block. The hose basically came loose and I dont know where it goes but I think it goes to the block right above the radiator hose?...
If someone can confirm this it would help. Also what is that came loose?
Old May 2, 2005 | 09:28 AM
shiftgear8000's Avatar
Default Re: Hose question next to Fuel Filter B16A2 (OoBryan)
I beleive that is your charcoal canister......not sure which hose you are talkin about though
Old May 2, 2005 | 09:31 AM
Default Re: Hose question next to Fuel Filter B16A2 (shiftgear8000)
Does one of your charcol canister hoses connect to the block?
I just want to make sure it goes there before I connect it.
But im throwing a code now and saw a hose loose....want to make 10000% sure it goes there lol...im a lil paranoid like that
Old May 3, 2005 | 07:08 AM
780
Old May 3, 2005 | 07:20 AM
Its right above the radiator hose
Old May 3, 2005 | 08:46 AM
EE_Chris's Avatar
Yes - The charcoal canister connects to the intake manifold. There should be a hose that comes from it, goes into the Purge solenoid, and then from there into the intake manfold. The purge valve is what opens to allow vacuum from the intake to suck out the fuel vapors the canister was storing.
If you want to be really sure, can you take a pic?
Old May 3, 2005 | 09:11 AM
Default Re: Hose question next to Fuel Filter B16A2 (EE_Chris)
Theres two hoses comming out of it. One is connected to the IM/TB area and the other one came out and im not sure from where
Old May 3, 2005 | 09:17 AM
EE_Chris's Avatar
Oh...I see.
If you have the line that goes to the IM already connected, then the other line leads back to the gas tank.
Old May 3, 2005 | 09:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Oh...I see.
If you have the line that goes to the IM already connected, then the other line leads back to the gas tank.</TD></TR></TABLE>
Thats not dangerous is it?...
Powered By Garrett
Jun 8, 2008 06:13 PM
GetawayInMoscow
Jul 25, 2007 08:09 PM
real_slow_EM1
Jan 26, 2006 09:52 PM
Dan GSR
Jan 22, 2003 10:03 AM
