5W-20 oil
Old May 2, 2005 | 08:33 AM
tony007's Avatar
Default 5W-20 oil
i put castrol CTX 5W-20 oil in my civic 1.5l, is this bad, do i need to change it?
Old May 2, 2005 | 08:34 AM
DJ_SaNdOz's Avatar
Default Re: 5W-20 oil (5genciv)
a thinner oil would be better suited to your car & the climate in TX
Old May 2, 2005 | 08:44 AM
tony007's Avatar
Default Re: 5W-20 oil (DJ_SaNdOz)
so like 10w-30
edit: do i HAVE to change my oil to a lighter one?
Old May 2, 2005 | 08:45 AM
tony007's Avatar
bump
Old May 2, 2005 | 08:47 AM
JDM-EJ1's Avatar
You'll be fine.
Old May 2, 2005 | 08:48 AM
DJ_SaNdOz's Avatar
it probably won't hurt the car, but it would be better to have a 5w 30 or 10w 30 in there.
Old May 2, 2005 | 08:57 AM
tony007's Avatar
ok, thanks guys, i really appriciate the help, so im safe? whew! good. thanks!
Old May 2, 2005 | 09:57 AM
tony007's Avatar
just to be sure, i am ok in texas, (moving to MN in june, driving) with 5W-20 oil? should i race with this oil?
Old May 2, 2005 | 10:13 AM
MR_EJ8's Avatar
Where in MN are you moving? im in souther MN and trust me with as cold as it gets up here your gonna wanna run 5-30 all year round!
Old May 2, 2005 | 10:14 AM
Toolman's Avatar
You will get better gas milage with that oil..
Since sports cars are coming out with that in their engines now id use it..
Old May 2, 2005 | 10:19 AM
JDM-EJ1's Avatar
Default Re: (Toolman)
I always use 10-30 on my Civic, it runs great.
Old May 2, 2005 | 10:24 AM
Toolman's Avatar
Default Re: (JDM-EJ1)
Mobile 1 is what I use in mine..
Old May 2, 2005 | 10:26 AM
Toolman's Avatar
oil sucks..
Old May 2, 2005 | 10:31 AM
Lmgrcivic's Avatar
warmer the climate you can use thinner oil but the colder the climate the thicker the oil you want its better for the motor that way
Old May 2, 2005 | 10:39 AM
AutoXer's Avatar
Default Re: (Lmgrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmgrcivic &raquo;</TD></TR><TR><TD CLASS="quote">warmer the climate you can use thinner oil but the colder the climate the thicker the oil you want its better for the motor that way </TD></TR></TABLE>
That is total misinformation. You want a lower viscosity (thinner) oil in winter to aid in startup. My manual recommends 5W-30 all year, but it says you can substitute 10W-30 in summer and 5W-20 in the winter.
Old May 2, 2005 | 11:58 AM
tony007's Avatar
Default Re: (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kory_69_187 &raquo;</TD></TR><TR><TD CLASS="quote">Where in MN are you moving? im in souther MN and trust me with as cold as it gets up here your gonna wanna run 5-30 all year round!</TD></TR></TABLE>
Eagan, near minn/st. paul
Old May 3, 2005 | 07:28 PM
HULKHATCH10's Avatar
a quick teaching.....if its cold were u are 5w-20 is good, in the cold weather the oil acts like a 5 weight when hot it acts like a 20 weight....which means ur car will star easier in the cold but it will not be protected during high temps and high revs......i read the manual.......i live in lawrence ma, weather here changes often so i use 10w-30 in the winter.....10w-50 in the spring ...and 20w-50 in the summer , if u have nice weather and hot sunny days , and u race use 20w-50 it protect at high temp, and high revs....and less noisy when redlining...makes a big diiference.. try it wont hurt the engine just protect it. holla back pce
Old May 4, 2005 | 11:18 AM
MR_EJ8's Avatar
Default Re: (5genciv)
Thats cool...i have a friend that lives in eagan...but yeah as far as the oil, i would just go 5w-30 all year round...and depending on how many miles you have, go synthetic.
Old May 4, 2005 | 06:48 PM
Bror Jace's Avatar
Default Re: (kory_69_187)
"You want a lower viscosity (thinner) oil in winter to aid in startup. My manual recommends 5W-30 all year, but it says you can substitute 10W-30 in summer and 5W-20 in the winter."
Thanks AutoXer for setting the record straight. Thick oil is murder in engines in cold weather.
In short, the 5W-20 oils protect most engines really well ... because they add extra additives like moly (Pennzoil, Chevron, etc ...) or boron (Motorcraft) to compensate for the reduced hydrodynamic film barrier.
Typical 5W-30 oils shear down to a 5W-20 in about 1,500 miles then gradually thicken back up over the next few thousand miles. This is by design as thinner oils offer slightly better fuel economy. 10W-30 is a bit more stable, but even that stuff tends to thin out fairly quickly.
V-Thang
Acura TL, RL & ZDX
Jan 9, 2004 11:04 AM
blkbeast
May 28, 2003 10:48 PM
d8168055
Nov 23, 2002 07:06 PM
RacerXintegra2k
Sep 12, 2002 11:34 PM
