QUESTION ABOUT CHANGING OVER TO OBD-1
Old May 2, 2005 | 05:00 AM
90 Si Hatch's Avatar
Default QUESTION ABOUT CHANGING OVER TO OBD-1
Ok I have a 90 Si hatch with a 96 Civic D16Y8 swap and it is still OBD-0 and I wanted to go go OBD-1 so i can get V-tec to come in. So what all would i need, Say what Dizzy, ECU, & Wiring. If any one could help me out it would be Great. Thanks
Isaac
Modified by 90 Si Hatch at 6:37 AM 5/2/2005
Old May 2, 2005 | 05:23 AM
Autoworks's Avatar
Default Re: QUESTION ABOUT CHANGING OVER TO OBD-1 (90 Si Hatch)
ECU, dizzy, conversion harness, and just wire your VTEC solenoid into your exhisting harness
Old May 2, 2005 | 05:37 AM
Default Re: QUESTION ABOUT CHANGING OVER TO OBD-1 (Autoworks)
But Which year dizzy, ECU, & where do i get the conversion harness
Old May 2, 2005 | 05:43 AM
EP3_05's Avatar
I am not 100% sure about the dizzy but you will need a P28 or P08 ecu, conversion harness, and a 4 wire oxygen sensor if you use the P28 ecu.
Check out:
http://www.rywire.com
Old May 2, 2005 | 06:08 AM
Default Re: QUESTION ABOUT CHANGING OVER TO OBD-1 (91civic)
Thanks man,
Bump any one else?
Old May 2, 2005 | 08:40 AM
Autoworks's Avatar
92-95 OBDI dizzy, check the performance parts forum, there is someone there selling the jumper harness
Old May 3, 2005 | 01:48 PM
but will the 92-95 Dizzy fit on the 96-00 head?
Old May 3, 2005 | 01:53 PM
rioninja's Avatar
Yes, but except for the z6 distributor.
Old May 3, 2005 | 02:42 PM
civicflow's Avatar
Default Re: QUESTION ABOUT CHANGING OVER TO OBD-1 (rioninja)
you could stay non OBD and just use a apexi vafc for vtec, just get it tuned on a dyno
Old May 3, 2005 | 02:51 PM
Bad89rex's Avatar
check em out.
Old May 3, 2005 | 03:11 PM
julio_bOostamante's Avatar
I'm a Jackass
Default Re: (Bad89rex)
or get an RPM switch from summitracing and hook up vtec to that. you could still stay OBD0 and avoid having to pay out more $$$
the switches are like 40 bux
Old May 3, 2005 | 03:13 PM
I'm a Jackass
Default Re: (julio_bOostamante)
here is the info i was talking about
http://store.summitracing.com/...h.asp
Old May 3, 2005 | 03:25 PM
njn63's Avatar
the rpm switch works but it's deffinatly not the best idea. You'll either be rich down low or lean up top. Not the best situation and deffinatly not maximizing the potential of the motor.
Old May 3, 2005 | 03:27 PM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but except for the z6 distributor. </TD></TR></TABLE>
are you serious? A non-z6 d-series distributor will fit a y8 head? I hope you're right because i'm about to swap my y8 mini-me to obd-1.
Old May 3, 2005 | 09:15 PM
civicflow's Avatar
Default Re: QUESTION ABOUT CHANGING OVER TO OBD-1 (njn63)
if you stay non OBD the apexi vafc would work since you could tune the air/fuel ON A DYNO/WIDEBAND w/VTEC.
Old May 3, 2005 | 09:26 PM
doublethink's Avatar
Default Re: QUESTION ABOUT CHANGING OVER TO OBD-1 (civicflow)
ok, but dyno time and a vfac is $$$ right there, just use the ecu honda intended and then mod IT later if you really want.
im not saying that way doesnt work, but not everyone has a wideband and free dyno time handy.
i dont really see any advantages of pre obd, except the cost of upgrading, which would be negated in the case of buying a bunch of **** to emulate an ecu that honda makes....
Old May 3, 2005 | 09:36 PM
civicflow's Avatar
Default Re: QUESTION ABOUT CHANGING OVER TO OBD-1 (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">ok, but dyno time and a vfac is $$$ right there, just use the ecu honda intended and then mod IT later if you really want.
i dont really see any advantages of pre obd, except the cost of upgrading, which would be negated in the case of buying a bunch of **** to emulate an ecu that honda makes....</TD></TR></TABLE>
YES, I agree w/you, just another way to make it work.
Old May 3, 2005 | 11:12 PM
Rywire's Avatar
You can use the y8 dizzy, no need to use a z6, internally the obd1/2 are the same, its basically just the plug that need to be changed out (well, theres more to it than that, ill take care of that tho!)
basically, if you go obd1, go ahead and use the y8 dizzy
Old May 4, 2005 | 05:35 AM
Default Re: QUESTION ABOUT CHANGING OVER TO OBD-1 (droppedcrxsi)
I had the MSD RMP Switch and that was a piece of ****, it didn't do anything at allll, my MSD switch is on ebay right now for sale. but as of right now I'm using my OBD-0 90 SI Intake manifold, Dizzy, and an 89 Integra ECU. with no v-tec and it was just like the D16A6 so thats what i'm working with now! and i called Rywire and i cant ever get ahold of any one. so who knows
Old May 4, 2005 | 09:01 AM
Rywire's Avatar
Im right here man, im the easiest person in the world to get ahold of (im always online).
Leave me a message, email, pm, whatever, ill get back with ya.
Ryan
si90rex
11
Feb 1, 2013 07:40 PM
jarhead90crx
12
Aug 5, 2011 07:06 AM
dbiker207
Apr 21, 2007 10:23 PM
dbiker207
.Unknown.
Dec 6, 2005 08:32 PM
