Car idles very low after turbo install (explanation + video clip inside)
Old May 1, 2005 | 11:18 PM
AzntaggeR's Avatar
TSPeed Factory
Default Car idles very low after turbo install (explanation + video clip inside)
after i got my turbo kit together it seemed to idle fine, until after i drove it for a while. after the cars been warmed up the idles will drop very low and will sometimes feel like it is about to die out.
here's my setup:
94 usdm b18c1
t3/t4e .63 a/r 57 trim
ssac manifold
3" open downpipe
fuel management:
rechipped p28 w/ uberdata on basemap
dsm 450cc w/ resistor box
walbro 255 fuel pump
-spark plugs are gapped to .030
-at stock ignition timing
-no vacuum leaks
-coolant is fine
video clip:
5.1 mb .AVI
notice how the idle drops to almost 100 rpms and the vac is only at like 15 in/hg
any ideas?
Old May 2, 2005 | 04:26 AM
ginoboy1978's Avatar
Default Re: Car idles very low after turbo install (AzntaggeR)
Honestly all i think you need is a tune. Put it on the dyno....get the basemap tuned.....you'll be fine.
DAN
Old May 2, 2005 | 07:22 AM
B16Civic93's Avatar
Default Re: Car idles very low after turbo install (ginoboy1978)
15hg is kind of low, check for a vac leak, you might have one even if you think you dont
MiraiZ's Avatar
looks like a vacuum clog
Old May 2, 2005 | 07:42 AM
SpeedingHatch's Avatar
Default Re: Car idles very low after turbo install (MiraiZ)
pretty much the same thing was happening to me.
My problem was with the ignitor. I Put in a new one, and it ran fine. A tune will help too.
Goodluck, problems like these sucks *****
Old May 2, 2005 | 08:20 AM
civickid13's Avatar
It sounds like something might be stuck in your vacuum line
Brandon
Old May 2, 2005 | 08:46 AM
adseguy's Avatar
Default Re: Car idles very low after turbo install (civickid13)
What is your fuel cut at? I have had one guys car i tuned have this value off a little and it idled horribly like that. Post up your bin. Maybe I can help
Also do you have a wideband...you could be running lean at idle, but I doubt it
Old May 2, 2005 | 10:20 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Car idles very low after turbo install (adseguy)
here's the basemap:
http://students.washington.edu...p.bin
Old May 2, 2005 | 10:35 AM
dustin's Avatar
Open or closed loop O2?
Old May 2, 2005 | 10:44 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: Car idles very low after turbo install (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Open or closed loop O2?</TD></TR></TABLE>
i always get them mixed up, but its the one that reads off of your maps rather then your o2 sensor. i think its on closed loop.
Old May 2, 2005 | 10:54 AM
dustin's Avatar
Closed loop -&gt; uses O2 sensor for fueling
Open loop -&gt; uses maps only
I opened that .bin you posted, and it IS using closed loop. If you are running that map identically, try disabling closed loop.
Old May 2, 2005 | 11:40 AM
adseguy's Avatar
1.) Disable closed loop (to only read off maps)
2.) disable 02 heater if you have a wideband
3.) What engine is this? If it's not a B18c5 then put your rev limiter back to stock ...you don't want to bend a valve
4.) You may take 20% fuel of of the idle columns to help with idle. Most people do this anyway because Uberdata likes to run rich .
What version of Uber are you using?
Old May 2, 2005 | 07:50 PM
AzntaggeR's Avatar
TSPeed Factory
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">1.) Disable closed loop (to only read off maps)
What version of Uber are you using?</TD></TR></TABLE>
its on a b18c1. i didn't make the basemap. my tuner made it for me so i can drive around a for a bit, and for the hour trip up north to where he is for the tuning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Closed loop -&gt; uses O2 sensor for fueling
I opened that .bin you posted, and it IS using closed loop. If you are running that map identically, try disabling closed loop.</TD></TR></TABLE>
if its on closed loop, wouldn't i throw a CEL for my o2 sensor since its not getting any type of reading from the exhaust gases? i'm running open downpipe.
birz
May 31, 2006 12:29 PM
drewlee
Oct 9, 2004 03:33 PM
forcedaccord95
Jul 25, 2002 09:05 PM
