Attn: Mechanics: 96 Accord Steering problems
Hi Guys.....
I ran over this Crate that fell off this ugly truck I was following on the interstate the other day,
And I took my 96 Accord EX to my mechanic who specializes in Hondas/Acuras,
The brake line to drivers side front whell was torn, resulting in a repair,
and the following pieces were bent or damaged,
: Lower left control arm
: Left control arm
then they had to take it to a body shop where those body shop guys pulled the frame forward on the left front end and replaced the left front strut rod.
I get my car back and now The steering is totally gone, feels like I have partial power steering and It is so hard to manuever this car now....
All parts used to fix it were supposedly new factory parts....could they have tightened something too much or too little?? Is it missing a part??
Any ideas??
Thanks...
The Wig
: Left control arm
Any ideas??
Thanks...
The Wig
Check your power steering fluid level first. You might have bent a tie rod, but I'm sure they would notice something like that... Man, I would think they would road test it for sure..
if they aligned the car did they give you the results?? camber, caster and toe readings frt + rear if so post them here i can read it and let you know if something is not right with specs.....if they did not give you specs see if you can get a copy of the results ....
in such impacts i have seen the rear cross member bent
hfbellosa
Sep 28, 2013 10:20 AM
canadaek
Jan 31, 2013 02:14 AM
accord96lx
Sep 22, 2012 01:53 PM
