weird burning smell after racing??
Old May 1, 2005 | 08:18 PM
itsJDMyo's Avatar
Default weird burning smell after racing??
i have a 95' LS swapped civic. the engine has 90k miles on it. i recently noticed that after i race, there is a burning smell from inside the car. smells like burning oil? is this normal or something? it never did this before. even when i'm just at a stoplight, and redline 1st and 2nd. after that, i can smell that burning smell. or is it just because my engine has a lot of miles or something?
Old May 1, 2005 | 08:21 PM
Deathwish's Avatar
Does it have the original cluch?
Old May 1, 2005 | 09:28 PM
dso's Avatar
dso
Default Re: weird burning smell after racing?? (itsJDMyo)
sounds like clutch burning , worst smell, for two reason, it's your money being burnt away (literally) and it's just a bad smell.
Old May 1, 2005 | 10:03 PM
Revolver's Avatar
Do you have any oil leaks?
Old May 1, 2005 | 10:05 PM
.Kevin.'s Avatar
i have that 2 but its because i have a header leak
Old May 1, 2005 | 10:06 PM
eg4usdm's Avatar
have you changed your oil recently?? maybe you spilled some somewhere like on the header/downpipe/cat and its burning off??
if not then its the clutch most likely like the other guys said
Old May 1, 2005 | 10:16 PM
chads's Avatar
Default Re: weird burning smell after racing?? (Slow_CvC99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 &raquo;</TD></TR><TR><TD CLASS="quote">i have that 2 but its because i have a header leak</TD></TR></TABLE>
me too, what header are you runnin?
mt greddy header seperates on hard shifts (from the cat) and i can smell it after that
Old May 2, 2005 | 06:35 PM
itsJDMyo's Avatar
Default Re: weird burning smell after racing?? (chads)
i have a stage 1 exedy clutch, and i recently changed my oil with mobil1 oil about 1k miles ago. and i'm running a stock header with the heatshield off (installing a 4-1 header in a couple days)
Old May 2, 2005 | 06:56 PM
snoochtodanooch's Avatar
probably burnt clutch if you are drag racing.
Old May 2, 2005 | 06:59 PM
Archidictus's Avatar
Unceasing Measure
Default Re: weird burning smell after racing?? (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">probably burnt clutch if you are drag racing. </TD></TR></TABLE>
Clutch smells nothing like oil. He's probably backing up oil in his PCV (which I can almost guarantee has never been replaced) or blowing it by his rings and/or valve stem seals.
The PCV valve is a relatively easy fix as compared to the other two...I'd look into that first.
Old May 2, 2005 | 07:04 PM
itsJDMyo's Avatar
Default Re: weird burning smell after racing?? (Archidictus)
the clutch isn't even a month new, so i really doubt it's that (although i have grinded it a few times already). and the PCV valve is on the IM correct?
Old May 2, 2005 | 07:09 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMyo &raquo;</TD></TR><TR><TD CLASS="quote">the clutch isn't even a month new, so i really doubt it's that (although i have grinded it a few times already). and the PCV valve is on the IM correct?</TD></TR></TABLE>
Underside of the IM, yes.
Old May 2, 2005 | 07:16 PM
sohcvtec1995's Avatar
did you properly break the clutch in? also you do burn oil in higher Rpm's so that could also be what you are smelling.
Old May 2, 2005 | 07:33 PM
itsJDMyo's Avatar
Default Re: weird burning smell after racing?? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">did you properly break the clutch in? also you do burn oil in higher Rpm's so that could also be what you are smelling.</TD></TR></TABLE>
yes i did. but i didn't notice this smell until a few weeks ago. and i've had this engine in my car for about 1 1/2 months now.
Old May 2, 2005 | 07:35 PM
true, the PCV would be reasonable. THe real test would be autox, if his PCV bad he would have a CLOUD of smoke coming out of the back after a long hard turn. Probably just bad rings is my bet. My car used to smoke pretty bad when it was being driven hard because it had a bad ring on #1. I never smell it though. With that being said i think it would be something leaking or burning in the engine bay in order for you to smell it. That would mean either an exhaust leak in combination with the bad rings/valve guides-seals or oil physically spilling somewhere.
Let us know what you find.
Old May 2, 2005 | 08:32 PM
itsJDMyo's Avatar
i'll try replacing the pcv and see if that will fix it.
Old May 2, 2005 | 09:24 PM
itsJDMyo's Avatar
and about the rings being a possibility, a while back, i was racing and one of my coolant hoses that goes to the IM busted, and white smoke started to pour out of my exhaust as i was racing down the track. and i didn't really notice it until i was almost at the finish line. so i basically raced a full 1/4 mile with a coolant hose busted off my IM. white smoke started to pour out of my exhaust and coolant shot everywhere in my engine. everything seems to be driving fine now, but could that be a possiblity that my rings might be bad?
Old May 2, 2005 | 09:40 PM
dso's Avatar
dso
i have the same clutch and i also smell is burning, under normal driving conditions. I have also only had it for a couple of months, but the smell went dissipated fairly quickly. so it prolly isn't the clutch if it is continually smelling the same.
Old May 3, 2005 | 02:43 PM
LudeEFv2.4's Avatar
My old title sucked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
The PCV valve is a relatively easy fix as compared to the other two...I'd look into that first.</TD></TR></TABLE>
you said it
crxricer66
Oct 3, 2007 02:41 PM
Fat Chick Magnet
Jul 23, 2006 05:55 PM
JDM B16A
Mar 21, 2006 01:36 PM
jond
Oct 6, 2005 11:17 AM
SantaCruz92Si
Apr 29, 2005 10:16 AM
