tire tread=gone
I was checking out my tires and I noticed this today... I know it had been worn, but it has gotten progressively worse. I finally decided to take it off and put my donut on when the steel started to show... What I don't understand is why only one side of the tire is worn badly. All of the other tires are fine. Someone told me I just need an alignment. Could it be like a bent suspension problem or something?
Heres a picture of the tire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapture »</TD></TR><TR><TD CLASS="quote">You need an alignment. Get your Toe adjusted back to 0. And get some new tires.
+1 ***** balder then patrick stewart!
</TD></TR></TABLE>+1 ***** balder then patrick stewart!
its CAMBER not toe.
http://www.ozebiz.com.au/racet....html
Alighnment is probly not going to fix it, how low are you???
toe can also cause tires to wear out like that. i used to have a REALLY bad problem with that. new tires. alignment..and everything is doing A ok.
also, those look like some shitty *** tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI »</TD></TR><TR><TD CLASS="quote">its CAMBER not toe.
Alighnment is probly not going to fix it, how low are you???</TD></TR></TABLE>
I just got my car and it's totally stock still. I just have an aem intake installed. The height is still at stock height. Ya they are shitty tires, they came w/ the car. I put an ad out for some si rims /w good tires though.
er i hope it's just an alignment.
Not likely, I am running almost -3* of camber in front, for about 2 years and I have NO abnormal tire wear whatsoever. I have my toe set to factory settings right now, which is why my tires wear so well.
its TOE not camber
Damn man, at least read the **** you tell others to read....
"For minimum tire wear and power loss, the wheels on a given axle of a car should point directly ahead when the car is running in a straight line. Excessive toe-in or toe-out causes the tires to scrub, since they are always turned relative to the direction of travel. Too much toe-in causes accelerated wear at the outboard edges of the tires, while too much toe-out causes wear at the inboard edges."
its TOE not camber
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave421 »</TD></TR><TR><TD CLASS="quote">its TOE not camber
"For minimum tire wear and power loss, the wheels on a given axle of a car should point directly ahead when the car is running in a straight line. Excessive toe-in or toe-out causes the tires to scrub, since they are always turned relative to the direction of travel. Too much toe-in causes accelerated wear at the outboard edges of the tires, while too much toe-out causes wear at the inboard edges."</TD></TR></TABLE>
lol, owned. Seriously people its incorrect toe specs not camber that kills tire. Look at that tire thats classic toe wear sloping wear across the contact patch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotsuma23 »</TD></TR><TR><TD CLASS="quote">Seriously people its incorrect toe specs not camber that kills tire.</TD></TR></TABLE>
LOL. This is like watching a game of ping pong.
Get your car aligned so that BOTH the toe AND the camber are within spec.
